Running board finish
Old May 21, 2013 | 07:35 AM
oldmerc's Avatar
oldmerc
oldmerc
I am going to use rocker gaurd on ours and paint over top . Rocker gaurd is meant to be painted so hopefully a scratch won't show up much with black on black . Also Mercury step plates .
Old May 21, 2013 | 08:07 AM
needhelp49's Avatar
needhelp49
if your gonna drive this truck and take it to the occasional show pile on the clear then every year or so you can wet sand the scratches out. I really like the bedliner on the ribs after everything is painted idea
Old May 21, 2013 | 11:59 AM
old_dan's Avatar
old_dan
I painted mine with a coat of epoxy primer, then POR-15 Chassis black....then painted them with Herculiner bed liner. I don't have any problem stepping on these!!
Old May 21, 2013 | 08:09 PM
tigerfan79's Avatar
tigerfan79
What about using some of the clear wrap that I have seen people use on the front of cars and such to protect against rock chips, etc? I was thinking of using a small section of that in the general area I will be stepping. If it ones not work I can pull it off without damaging the paint I suppose.
JaySVX
Jan 13, 2012 07:02 PM
$Bruiser$
Oct 7, 2010 09:17 AM
51f1truck
17
Mar 15, 2009 08:05 PM
nchokie
27
Oct 13, 2003 07:08 PM
billb7984
26
Sep 18, 2003 10:25 AM
