Dana 60
Old Mar 1, 2013 | 01:33 PM
kmorgancraw's Avatar
kmorgancraw
Dana 60
I have a lead on a Dana 60 rear for my 49 F2. I havn't seen it yet but based on the tag number provided it looks like it came from a
1971-72 F-250 3/4 Ton HD 4x2 Pick-up - Full-Float
according to dana.com and a pdf they provide.
The HD has me concerned as there are non HD axles as well. Is this the correct axle for my 49? The numbers off the tag are:
D0TA-AS
603195-5 3.73
Thanks for any help!
Old Mar 1, 2013 | 04:25 PM
raytasch's Avatar
raytasch
Believe Nothing
I don't remember all the details but back about then or later Ford built some F250s with lighter three quarter floating rear ends. A full float is easy to ID with the big hub sticking outside the wheels.
And welcome to the forum.
Old Mar 1, 2013 | 05:47 PM
51dueller's Avatar
51dueller
The only LD 3/4 pickup rear ends Ford used were in the late 80's and early 90's. They were semi float.
The HD refers to the front suspension. The LD used F-100/150 size brakes and the HD used the F-350 brakes.
Old Mar 1, 2013 | 05:50 PM
kmorgancraw
But I do want full floaters right?
Old Mar 1, 2013 | 07:48 PM
59JEEPSTANG's Avatar
59JEEPSTANG
Yes you want a full floater. The D0 means 1970 design. They also had semi floaters in 83 and 84 on Ford Diesels, had a friend take his truck back to the dealer when he popped the hub cap to find a semi floater behind it....Ford ended up replacing the axle assembly, said they did it when they were short on parts.
Paul
mjf250
Apr 12, 2018 07:47 AM
StephenJones1123
Oct 31, 2009 02:12 AM
55F250
Aug 12, 2009 03:55 AM
Rob Cuenin
Apr 14, 2009 07:00 PM
7d2 Custom
Nov 20, 2008 03:15 PM
