6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
oil analysis
Old Jul 3, 2013 | 04:27 PM
StanleyZ's Avatar
StanleyZ
The report says "valve train", I wonder is there nickle in the rocker arms. I don't think so but they are a common point of failure on 6.4s and I think you said you were at 136,000. Might be worth asking them what part of the valve train.
Old Jul 4, 2013 | 10:08 PM
Tom's Avatar
Tom
Attached is Joe's UOA report.
File Type: pdf
Old Jul 5, 2013 | 05:02 AM
senix's Avatar
senix
Thanks Tom.
That is some pretty severe wear.
Old Jul 5, 2013 | 02:41 PM
GHeTTo JOe's Avatar
GHeTTo JOe
so what are some recommendations? looks like the main concerns are Nickel and Iron. it states that Nickel could be found in camshafts, valve trains, turbo cam plates, turbine blades and roller bearings. what would the Iron all be found in? also i seen another sample from Blackstone on here that they stated low silicon levels show good filtration. maybe i need a new air filter also? maybe ill change the oil slightly sooner and send a sample to Blackstone see if they concur with these findings on the next sample. do you guys think they would take a copy of this sample to know some history of the previous sample?
Old Jul 5, 2013 | 06:13 PM
StanleyZ's Avatar
StanleyZ
I feel sure they would, just stick it in the tube with the rest of the paperwork and a note telling them what you want. I still think I'd be coincerned about the rocker arms. Don't know any way to check that though except pull the valve covers off and take a look.
Old Jul 5, 2013 | 08:15 PM
senix's Avatar
senix
You can shine a light and look into the fill tube but the only way to really check is the pull the valve covers.
Old Jul 6, 2013 | 12:36 PM
GHeTTo JOe's Avatar
GHeTTo JOe
i was just thinking if i had towed on that oil and remember that we took it snowmobiling up in iron river wiscosin so like 600 miles round trip of towing a v nose 4 place snowmobile total weight at around 19000# driving 80mph and on the way back into a strong wind gusts in 30mp. now i know this is not many miles of the oil change but that that could be considered heavy right?
Old Jul 6, 2013 | 04:33 PM
Tom's Avatar
Tom
Sure it's heavy, but every engine put into these trucks is designed to do just that. I've never heard of seriously increased wear metals caused by towing. Going with that, I've never heard of anyone's engine life reduced by towing either. Wide-open, all day long, you shouldn't hurt it.
AK_SuperDuty
Oct 12, 2023 11:46 AM
Firefighter 1406
19
Jan 13, 2018 06:03 PM
Johnnybee
6.7L Power Stroke Diesel
18
Feb 13, 2014 12:40 PM
buzz211_11
24
Apr 27, 2011 01:12 AM
pat2724
1997 - 2003 F150
Jun 20, 2007 07:01 AM
