All power points not working
Old Feb 28, 2013 | 01:54 PM
Pitcrw6's Avatar
Pitcrw6
The wife called me up and said none of the power points are working including the cigar lighter. She checked the one in the very back, the one on the back of the center counsel and the two on the dash and no power. She checked the fuses, 2, 3, 4, 5, 6 & 12 and all were good. Is there a relay or something else that I can check? Its a 02 X so there are no fuses in the engine bay from what I remember. Shes driving up to SC from FL on saturday so I can look at it then. Just wanted to get an idea of what to look at before she gets here. Also she said she drove through some water but went slow because it was about 10 inches deep.
Old Mar 1, 2013 | 09:06 AM
Pitcrw6's Avatar
Pitcrw6
Bump....anybody have any idea what I can check?
Old Mar 1, 2013 | 09:46 AM
golfmedik's Avatar
golfmedik
Are you sure there is not a relay or another fuse in here:?
I didn't have time to go through the manual, but there is something that has blown. Big fuse or relay. Did you test each of the fuses instead of just looking at them? Just throwing out suggestions.
Old Mar 1, 2013 | 10:59 AM
Pitcrw6's Avatar
Pitcrw6
Why cant I view pics on the mobile site anymore?
I'll have to jump on the computer to see the pic u posted. I haven't tested anything yet cause the X wont be here till tomorrow but I plan on checking it all out. The fuses were just pulled out and looked at so she didnt test them. From what I remember the X is the same as my 02 F350 where there is only 2 or 4 relays in the engine bay and all the other fuses and relays are under the dash.
Old Mar 1, 2013 | 11:27 AM
Diablo540's Avatar
Diablo540
A fuse can look good and test bad i see this at work quiet often bit im also working on the mail trucks that have loose connections, corrosion and hack repairs from some of our past contractors
Old Mar 1, 2013 | 11:30 AM
Pitcrw6's Avatar
Pitcrw6
I know for a fact my X does not look like that. I'm having the wife take a pic of that area and sending it to me then I'll post it. But I beleive the 02 & 03 MY changed from the 99 - 01 MY.
Old Mar 1, 2013 | 03:55 PM
Pitcrw6's Avatar
Pitcrw6
Heres a pic of the relays I have in the enging bay. I will ck it all out tomorrow when she gets here. I hope its an easy one.
Old Mar 4, 2013 | 07:37 PM
gurinder_s_gill's Avatar
gurinder_s_gill
So Did you find out what was wrong there. My Ex seems to have the same problem - all fuses look good but have been unable to get to it due to a bad injury. Came across this post and thought I could learn something and be better prepared before I go out and check the wiring and the relays. Thanks
Old Mar 4, 2013 | 07:58 PM
Pitcrw6's Avatar
Pitcrw6
Well I got around to looking at the problem today and come to find out all the power points work except for one on the third row seats cup holder. The cell phone charger my wife was using was what was bad. I wont even try and fix the one power point that is out unless someone has a easy fix for it. I'm thinking that I would just have to replace the power point itself since that is the only one not working but I will ck the fuse again just to make sure.
StillNotKing
21
Sep 28, 2021 08:19 AM
h400bear
Aug 28, 2020 07:46 PM
grif95
May 27, 2016 06:26 AM
sparkyone
1997 - 2003 F150
Aug 30, 2010 10:36 PM
