Sponsored by: Auxito
power windows quit working
Old Aug 29, 2010 | 06:39 PM
sparkyone's Avatar
sparkyone
I have 2002 f-150, and the power windowes just stopped working, checked for voltage at the main switches(driver side) and nothing.I looked in the owners manual and it states space 601 CB,under the hood and there is nothing in that spot, is there away to reset this??? CB= circuit breaker im guessing.Then there is a relay for the automatic down on the power windows under the dash relay 4, i cant test the fuse box there my meter leads wont go in the spaces, SO now im stuck. Any help would be nice thanks.
Old Aug 30, 2010 | 10:36 PM
Bluegrass 7's Avatar
Bluegrass 7
CB601 is for super crew model.
Look at fuse 25, a 30 amp fuse.
The power from this fuse goes thru the Acc delay relay.
This relay is operated by the GEM module and passes power to the one touch switch.
You will have to see if it's the main fuse or the Acc relay not coming up or has open contacts or faulty Gem module.
For circuit info, see the Haynes manuel page 12-26.
Good luck..
Beeler
Nov 13, 2016 01:15 PM
Debdoodle
1997 - 2003 F150
Apr 12, 2015 11:48 AM
5.0 Heaven
Escape & Escape Hybrid
39
Jul 14, 2011 07:18 AM
Diesel 724
Nov 1, 2010 01:20 PM
nsjoblom
Sep 9, 2009 05:58 PM
