Oil Leak
Old Feb 27, 2013 | 03:43 PM
Shadowrider123's Avatar
Shadowrider123
Oil Leak
I think Im getting oil out of the tranny, up the speedo cable and on the cab floor.
How do I fix this?
Old Feb 27, 2013 | 05:05 PM
TA455HO's Avatar
TA455HO
Lead Gopher
Most transmissions have a vent to the atmosphere so pressure doesn't build up inside. If that vent were to be plugged or otherwise became inoperable then pressure could build up. Speedo cable might be a path of least resistance. What transmission do you have? I know the NP435 4-speed has a fairly large vent and I can point you toward where it should be. Others might chime in for other transmission types.
Old Feb 27, 2013 | 05:35 PM
Shadowrider123
Its a 66 F100 352/3 spd
Old Feb 27, 2013 | 09:57 PM
TA455HO's Avatar
TA455HO
Lead Gopher
Can you reach up behind the cluster and feel oil around where the cable attaches to the speedo head? It should generally be almost bone dry on the outside of that connection. If there's much oil there it's probably getting inside the speedmeter, too, but hope not.
superdutyranger
Oct 29, 2006 08:11 PM
Six Niner
Jan 11, 2006 07:27 AM
inliner
Feb 18, 2004 05:55 AM
emboyd
Aug 22, 2003 08:01 PM
inliner
Jun 12, 2003 06:11 AM
