Grinding noise????
Old Feb 27, 2013 | 02:39 PM
tom_salisbury's Avatar
tom_salisbury
Grinding noise????
I often hear a grinding noise after hitting bumps in the road. The noise only stops when i pull over and stop or if i switch to four wheel drive high range. any help would be appreciated.
Old Feb 27, 2013 | 04:10 PM
slovride's Avatar
slovride
Where is the location of the grinding noise? Front, back, left, right, is it in the wheels, engine etc? If it is in the wheels could be alot of things like a brake dragging, or wheel bearings. My friend has a '02 Explorer and has replaced every wheel bearing at least once and some twice and has only had the car himself for 4-5 years... Give more info and will try to throw out ideas.
Old Feb 28, 2013 | 12:57 PM
tom_salisbury
It seems to be coming from the front end or the wheels. I just dont understand why it stops when i shift into high range four wheel drive. could it be the hubs?
Old Feb 28, 2013 | 02:08 PM
slovride's Avatar
slovride
Well if its a bearing jack up the truck and see if there is excess play in the hub, and spin it and listen for grinding. If its possibly a cv joint look at the boots to see if they are torn and when driving steer lock to lock and see if there is clicking while moveing. As far as 4x4 hub I am new to four wheel so hopefuly someone else knows your 4x4 system well to help you
Old Mar 1, 2013 | 11:25 AM
tom_salisbury
Ill look into it more thanks for your time.
Old Mar 2, 2013 | 06:17 PM
slovride's Avatar
slovride
np let everyone know and we'll keep narrowing down the prob.
Old Mar 2, 2013 | 06:32 PM
Tinstar36's Avatar
Tinstar36
Sound like a hub have no idea what you truck is so it is a guess but the ford auto hubs are know to have problem as they get older
resq302
Aug 21, 2018 10:29 AM
blais42
Dec 8, 2014 11:53 PM
Ekkehard
2004 - 2008 F150
Nov 4, 2012 02:58 PM
Mr.Russell
2004 - 2008 F150
Aug 7, 2008 10:20 PM
Twisted Light
1983 - 2012 Ranger & B-Series
Mar 2, 2007 07:28 PM
