Sponsored by: Real Truck
Electrically frustrated......
Old Feb 27, 2013 | 11:45 AM
rowley's Avatar
rowley
Angry Electrically frustrated......
so I posted this last night and I'm still looking and testing. Thought I would try again today when more people are looking. soe here goes. I have a 1999 V-10. So the other day I went to start the truck and when I turned the key the dash lights started blinking and chattering like the battery was dead, however it turned over. But upon starting the engine was missing and black smoke was coming out the tailpipe. Not good. So I turned it off and tried again same. Let it sit for a minute and tried again and it started fine. Check the codes nothing. Driving today to work and it did it again, loss of power, started missing and died. Turned it off and started up again all good. Check battery and determined it was bad so i replaced it. Driving home all was good then once again the same. each time no codes. I would suspect a ground but can't find one. Any suggestions.
Old Feb 27, 2013 | 01:25 PM
BPofMD's Avatar
BPofMD
Veteran: Navy
Check your battery GROUNDS! From engine to battery and any other grounds from frame to body/battery etc. Sounds like rust may have invaded the ground lugs. Remove the ground and wire brush and clean all the connect points. The ground connection is just as important as the hot leads.
Geez, I see now that you have another post about this same issue. People told you there pretty much what I just did...... NO this does NOT sound like a PCM.
Old Feb 27, 2013 | 02:48 PM
rowley's Avatar
rowley
I appreciate your response and everyone else. Just wanted to double check its just nice to be reasured. I have checked the grounds and did some voltage drops and checked fuses and still the same. But haven't given up hope. Just wanted some more ideas. Thanks again.
PiP.Squeak
29
Apr 4, 2015 11:08 AM
rowley
Feb 28, 2013 07:20 PM
72CC428
Sep 15, 2012 07:17 AM
jwford93
Electrical Systems/Wiring
13
Jan 5, 2006 08:41 PM
tmanpa
Jan 8, 2004 09:05 PM
