88 fuel pump ????'s
Old Feb 27, 2013 | 09:03 AM
88dually's Avatar
88dually
88 fuel pump ????'s
engines getting rebuilt with a cam, heads an maf. i have 3 fuel pumps, the 2 in tank pumps will be 255 lph's.
question; can i eliminate the frame pump ? or does it have to match ? if it gets eliminated, what do i do with the wires to it ?
Old Feb 27, 2013 | 09:28 AM
subford's Avatar
subford
That depends on the pressure the tank pumps will put out and if the engine is FI or non FI.
Old Feb 27, 2013 | 11:05 AM
junglemike49's Avatar
junglemike49
I would say keep the main frame($70)and the high pressure one. the internals are harder to replace and $130. junglemike49
Old Feb 27, 2013 | 08:39 PM
88dually's Avatar
88dually
Bill, the in tank pumps run around 90 psi
Old Feb 27, 2013 | 08:56 PM
subford's Avatar
subford
Then you would not need the frame pump.
Just tape off the wires and tie them back.
I think you can bypass the frame pump by just plugging the line from the rear into the fuel filter and plug the pressure line going to the fuel rail into the other end of the filter.
The pressure line from the tanks should go into a "Y" and then to the fuel filter.
Old Feb 28, 2013 | 02:25 AM
88dually's Avatar
88dually
THX Bill .
Doostien
Nov 16, 2014 06:20 AM
Andy1416
Bronco II
Jul 11, 2013 01:32 AM
junglemike49
Feb 27, 2013 12:11 PM
GregonVI
Jun 16, 2012 04:43 PM
amw_drizz
Bronco II
Jan 9, 2005 01:00 PM
