Torque specs
Old Feb 26, 2013 | 04:17 PM
Leeboy1962's Avatar
Leeboy1962
Torque specs
Insatlling a AOD and a new flywheel,164 tooth,50oz weight,in my 1981 Ford F150,302,Can someone tell me the torque specs for the flywheel bolt ,torque converter bolts torque spech,trans bolts torque spechs,THANKS AGAIN IN ADVANCE
Old Feb 26, 2013 | 04:39 PM
81ChopTop's Avatar
81ChopTop
Flywheel - 75-85 ft lbs
Torque converter nuts - 20-30 ft lbs
Trans filter to main body - 80-100 in lbs
Trans pan bolts - 10-14 ft lbs. - I would suggest to just snug them down though. There's a couple of bolts that don't have much thread and can easily strip.
You say 50 oz counter weight, what year is your engine? If you put the 50 oz flywheel on a 28 oz crankshaft, you'll tear up the bearings.
The weights changed in mid '81.
1989FordF250
Oct 15, 2017 10:11 PM
jle70
Nov 14, 2009 02:06 PM
topgunn
Aug 15, 2007 01:38 AM
cranky42
May 14, 2007 09:04 PM
