flywheel bolt torque lbs.
Old Aug 14, 2007 | 02:07 PM
topgunn's Avatar
topgunn
Cool flywheel bolt torque lbs.
What is the correct torque lbs on the flywheel to crank flange. What are the threads, the bolts check out to be 10mm x 150 not 3/8 -16 n.c.. I am swaping my E40D for a zf5 and bought a s/m flywheel conversion from CMI Industries through NAPA, almost everything comes from China. The package says they are certified to ISO 9001:2000. The instructions say to torque their supplied bolts( six lines mean grade 8, correct) to 45 - 49 lbs. Three out of the nine would not even go to 40 before they seemed to get easier to turn, I removed them and got replacements from NAPA. Again four would not torque past 40, one even was cracked, luckily I stopped in time and removed it. The original bolts are 1/4" too short. The ones from NAPA are stamped rockwell. Thanks for any help.
Old Aug 14, 2007 | 06:26 PM
catfish101's Avatar
catfish101
A 10mm by 1.5 10.9 is 45lbs a 12.9 is 49 lbs.
I would get another torque wrench. A 3/8 grade 8 shouldn't be stretching at 45 lbs. No matter who makes the fastener, the ANSI standard on a grade 8 bolt is 150,000 lbs tensel strength.
Are they bottoming out? Any bolt will break pretty easily then.
I would try to find you another wrench to try. They will get out of wack. I have mine checked once a year unless they start acting funny thens it's sooner. Also if it is a spring tension style wrench, twist the handle and tighten a main spring up in the handle, and they sit around with pressure on them they will get messed up. That is a big no-no.
Old Aug 15, 2007 | 01:38 AM
topgunn's Avatar
topgunn
Thumbs up
Thanks catfish, I never thought about that. I have used that wrench for many years, maybe time for a new one.
robert copeland
2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6
17
Mar 9, 2021 10:35 PM
DeeV8er
Jun 10, 2013 09:47 AM
rickm15752
Jan 6, 2012 07:21 AM
deere81
Jun 9, 2001 11:20 PM
