Oil Pan Remove/Replace w/o Lifting Engine?
Old May 31, 2003 | 10:52 PM
jimfrentress's Avatar
jimfrentress
1990 F250 4x2 351 - can I remove the oil pan without lifting the engine and then replace the pan after I check my oil-pickup tube and oil pump for problems?
I assume I need to remove the exhaust at the manifolds. If I do need to jack the engine up, where should the jack point be and do I need to loosen anything else besides the two (2) side motor mounts? Anything else I need to consider or tricks/tips I can use?
Any information I can get on this would be greatly appreciated.
Old Jun 1, 2003 | 02:09 AM
joners's Avatar
joners
I wouldn't jack the engine up. I would use an engine hoist.
Old Jun 1, 2003 | 03:25 AM
cajunbronco's Avatar
cajunbronco
Try there,also do a search on the truck forum
CB
Old Jun 1, 2003 | 01:04 PM
jimfrentress
Found exactly what I need at your link (and a ton of other stuff I can use as well.) Thanks a ton!!
Old Jun 14, 2003 | 12:24 AM
RA101524's Avatar
RA101524
Cajunbronco - thanks for the great link. I'm just getting ready to drop the rusted out oil pan on my '90 F-150. Your info should help a bunch.
TruckDoggy
Aug 6, 2012 06:57 PM
1985f350
Sep 29, 2007 12:23 PM
monkei
Oct 3, 2003 12:46 PM
jimfrentress
Jun 2, 2003 12:12 AM
