glow plug removal
Old Feb 26, 2013 | 11:22 AM
f1501987's Avatar
f1501987
glow plug removal
Im removing my gp, first theres oil sitting on top of each one. do i remove the oil first? second, Iv read that the piston on cylinder one has to be on tdc? or can i just remove then all very carefully.
Old Feb 26, 2013 | 11:23 AM
97XLT4X4's Avatar
97XLT4X4
i would just take them all out at once, dont worry about tdc, i wiped up some of the oil but what i did....with them all out, i disconnected the CPS and cranked it over to blow oil out. are you replacing the valve covers, harness, and relay as well?
https://www.ford-trucks.com/forums/1...-are-good.html
thats my gp thread
Old Feb 26, 2013 | 12:00 PM
fordpride's Avatar
fordpride
It's doesn't need to be at TDC. You don't have to remove pushrods
Old Feb 26, 2013 | 12:04 PM
f1501987's Avatar
f1501987
Yea im replacing the harness and gps, whats the cps? crank postion sensor? and you say u cranked it with the vc off?
Old Feb 26, 2013 | 12:22 PM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Wink
Yes and yes
Old Feb 26, 2013 | 02:26 PM
21411's Avatar
21411
yup when i was getting ready for mine, some one had to redo theirs cause oil got in the cylinder and locked it up. it might blow a mist, might not. i felt better knowing there was no oil puddles in side.
just checked the time stamp, you should be about done. hope all went well.
Old Feb 26, 2013 | 02:37 PM
97XLT4X4's Avatar
97XLT4X4
cam position sensor, it right behind the crank pulley.
so how did it go!?
Old Feb 26, 2013 | 02:47 PM
f1501987's Avatar
f1501987
Got it all done went well. Old plugs didn't look to bad, iv got a buzzing sound from the , it used to not do that. What could it be
Old Feb 26, 2013 | 03:00 PM
FI460's Avatar
FI460
Did you also replace the glow plug relay? I just did gp's and the relay and have a buzzing now that I didnt before. I assume it is the relay because it stops when the relay shuts off.
Old Feb 26, 2013 | 03:03 PM
f1501987's Avatar
f1501987
Yea, it's not new relay but got it from a guy that has a Diesel garage, he says it's good, it seems good
Old Feb 26, 2013 | 03:17 PM
97XLT4X4's Avatar
97XLT4X4
mine buzzed too. i just (literally just finished)put two new harness side valve cover connectors and now it has a solid click when i put key to on. id check those valve cover connectors again
Old Feb 26, 2013 | 03:29 PM
f1501987's Avatar
f1501987
I only did one side so far. Other side looked good
Old Feb 26, 2013 | 03:49 PM
97XLT4X4's Avatar
97XLT4X4
one connector had an entire glowplug port melted off and the other one made no contact
Old Feb 26, 2013 | 03:50 PM
f1501987's Avatar
f1501987
Mine starts great, no smoke just buzzes
Old Feb 26, 2013 | 03:53 PM
97XLT4X4's Avatar
97XLT4X4
i gotcha, mine was buzzing, i figured it was similiar. you could have one dead one still possibly
