glow plug removal
Feb 26, 2013 | 03:55 PM
Could i maybe unplug each and turn key on
Feb 26, 2013 | 04:01 PM
you could test them through the connector....i dont remember if its power to ground or vise versa.....someone more nutty will chime in im sure!
Feb 26, 2013 | 05:59 PM
Well thought i.did good till i drove it. Smoking white real bad and sounds awful. What did i do wrung. Still has good power until i try to pull out
Feb 26, 2013 | 06:02 PM
More a bluishwhite sounds rough
Feb 27, 2013 | 07:48 AM
did you mess with the injector harnesses under the valve cover? im still leaning toward the connector/harness from my experience recently
Feb 27, 2013 | 07:52 AM
The new uvch comes with the plugs for the injectors don't it? Im guessing i wrired plus rong on out side.
Feb 27, 2013 | 08:13 AM
yea,my new valve covers came with everything....these are where my problem was, i remember a member saying his truck ran ok at idle and shoke/had low power with a missing injector
glow plugs are outer most ports....
Feb 27, 2013 | 09:04 AM
Yes mine did to, so what's this pic meaning towards?
Feb 27, 2013 | 09:30 AM
when you did the glowplugs, you may have left/knocked of an injector connector, or the pins on the valve cover, or that connector may be screwed up or burnt. did you disconnect anything else
Feb 27, 2013 | 09:40 AM
Yea i replaced pig tails, replaced all connectors under vc
Feb 27, 2013 | 10:05 AM
Sounds like you may have wired the pigtail wrong
Feb 27, 2013 | 11:05 AM
Got a good scanner, says idm at fault, miss firing ever other cylinder
Mar 1, 2013 | 07:58 AM
Mar 1, 2013 | 02:50 PM
Yea, got to looking at it and had the wires crossed.runs great now
Mar 1, 2013 | 05:52 PM
Quote:
Originally Posted by
fordpride
f1501987
And the winner was .........
I tried to rep Mike, but NO dice
KennySpencer
22
Jun 9, 2014 12:42 PM
ericbskis
Oct 29, 2013 01:31 AM
Dan Taylor
Sep 23, 2012 06:37 PM
tracyclifton
Jun 3, 2012 11:10 PM
butchf350
Mar 8, 2006 06:26 AM
