302 EGR valve
302 EGR valve
When I got a new EGR valve, the one that attaches to the plate, I noticed it came with a package of discs that fit in the valve in a little recess. They have different hole sizes, from fairly large at 7/16" to a pinhole.
Which size is appropriate for a 302 with a Comp cams 268 and Holley 600 cfm 4 bbl, and 9.7/1 compression due to replacing the stock dished 8.0/1 pistons for flat tops?
Also the temperature vacuum switch to control it has 2 ports, which one goes to the vacuum source and which one to the valve?
Does the EGR use ported vacuum like the spark advance, or straight vacuum?
Thanks.
Thanks.
Resto
19
03-02-2018 07:15 PM
daddy172005
06-20-2008 10:21 AM
