Sponsored by: Auxito
1997 F-150 issues
Old Feb 25, 2013 | 10:57 AM
Redneckryder's Avatar
Redneckryder
1997 F-150 issues
I bought a truck last week, wasnt running right. Has a miss, and the longer you drive it, the worse it gets. I have changed out the coils, and it didnt help. I am trying not to spend too much, but I am not sure what is going on....any more ideas?
Old Feb 25, 2013 | 11:50 AM
dvlsmstr's Avatar
dvlsmstr
Should have changed the plugs when you were changing the coils.
Old Feb 26, 2013 | 09:02 AM
KhanTyranitar's Avatar
KhanTyranitar
Also replacing parts without diagnosing the problem is gonna burn through a lot of money very quickly.
Old Feb 26, 2013 | 08:39 PM
galaxie641's Avatar
galaxie641
Yeah, really need to know which cylinder is missing. #3 or #4 could be from a coolant leak for example.
Old Feb 27, 2013 | 06:19 AM
projectSHO89's Avatar
projectSHO89
The 97 4.6 uses plug wires. Wires and the plugs should have been looked at before the coils.
Old Feb 27, 2013 | 07:40 AM
Spotty's Avatar
Spotty
Yeah....take a good look at wires. I have a 98 and wires always seem to be the problem. If it is missing that bad it will toss a code. Mine was doing the chug a lug one morning last week....hooked up my code reader....mis-fire on #2. Plug wire had popped off...even though it snaps on tight... Wires are not even a year old. As mentioned look at #1thru #4. Those are on the passenger side with #1 closest to the front. Water or coolent from hoses above, the squirter on the hood, or a cowl leak get into that area and then rolls back and forth and drips into those four spark plug wells. It takes a loooooooong time for a spark plug well to dry out with the boot still intact.
Old Feb 27, 2013 | 09:06 AM
MIKE 04 GT's Avatar
MIKE 04 GT
go to auto zone, are advance the have code readers and will check it for you free. or if the truck cant drive, they will rent you one.
Old Feb 27, 2013 | 09:29 AM
Spotty's Avatar
Spotty
Yeah...lots of places have them now you can use. I really think if you are going to self diagnose a vehicle these days, some type of code reader is must. Mine was like $95 bucks and it tells the code and the meaning....like code "whatever" then will say "mis-fire on #2". Then you can go right to the area in question. OBD 2 is really comprehensive to the old OBD 1. As a kid I owned a dwell meter and a timing light and a vacuum gauge. The vacuum gauge is still a valuable diagnostic tool, but my code reader has replaced the other two.
Old Mar 15, 2013 | 10:31 PM
Redneckryder
I feel stupid.....Plugs and wires fixed it.....I should have known. Thanks for the responses.
expensive_habit
Feb 16, 2014 01:12 PM
fiyrman
1997 - 2003 F150
Oct 16, 2006 06:23 PM
jakef
1997 - 2003 F150
May 21, 2006 09:36 AM
jacobs
Modular V8 (4.6L, 5.4L)
May 9, 2004 08:37 PM
da_vinci_1
1997 - 2003 F150
Jul 1, 2002 08:59 PM
