Modular V10 (6.8l)
miss fire issue
Old Feb 24, 2013 | 10:44 PM
SMonroe's Avatar
SMonroe
miss fire issue
looking for a little help.
2004 F250 SD 4x4 109k miles
Truck developed a really bad miss no codes. Changed the plugs, coils, boots, fuel filter, injectors, and air filter as well as cleaned up the intake and PCV. Truck ran great for about 200 miles but now i have a random miss at low RPM worse when cold and under a load. I changed the MAFS and it seemed better but still not 100%
Any suggestions.
Old Feb 25, 2013 | 12:03 AM
jh818's Avatar
jh818
No water in the spark plug holes?
Old Feb 25, 2013 | 05:50 PM
SMonroe's Avatar
SMonroe
No water in the holes I pulled all the coils the other day to see if I had that issue or maybe damaged a boot during the install. I didn't see anything wrong.
Old Feb 27, 2013 | 05:28 PM
86ford302help's Avatar
86ford302help
what does it mean when there is water in the holes? I have a 2001 5.4L and i have a slight miss fire sort of on and off. when i pull the coil pack then there is water in the hole.
Old Feb 27, 2013 | 08:11 PM
jh818's Avatar
jh818
Water in the spark plug holes means that most likely is the cause of your misfire. The rubber of the boot insulates the spring inside from the negative ground (engine block). That water becomes a conductor and shorts the 2.
It's kind of like the same reason they say to get out of the swimming pool when there is a thunderstorm.
01f250v104x4
Feb 5, 2017 04:24 PM
Jason01
Modular V8 (4.6L, 5.4L)
May 10, 2008 11:21 AM
almost_nick
1997 - 2003 F150
Feb 11, 2008 12:02 PM
SZMatters
Feb 9, 2008 02:51 PM
onehit45
1997 - 2003 F150
Apr 1, 2007 08:38 PM
