Sponsored by: Auxito
Stop The Squeaking II!!!!!!
Old Feb 23, 2013 | 10:43 PM
Club Wagon's Avatar
Club Wagon
'98 F-150 4X4 XLT began squeaking recently. Have 1/2 mile long sand & limerock driveway thru mature North Florida jungle & every root'n'bump makes it squeak.
Was certain it had to be the J.C.Whitney/Owen's running board I left on passenger side. Upon close inspection, wrestling with it & popping it with big rubber mallet was surprised to find it tight & silent.
Checked bumper & associated bolts, then exhaust & everything else I could see/touch sliding under on a moving quilt. Notta!
Does not sound like bushing or ball joint. High pitch squeak, up near the annoying frequency of nails on chalk board.
Old Feb 23, 2013 | 10:51 PM
JWC 3's Avatar
JWC 3
I hear a lot of ball joints make that type of noise . Ck them just to be sure . They can show signs of rust , or look fine . Just a thought .
Old Feb 23, 2013 | 11:29 PM
Doc's Avatar
Doc
Any chance it's the pitman arm bushing as you're turning the wheel? Mine started squeaking LOUDLY when my truck was just barely a year old. Especially when I was at low speeds in parking lots, etc. It was embarassing as hell. A grease needle fixed it instantly. Just a thought. I know you said it happens over bumps, but I just thought I'd throw it out there.
Old Feb 24, 2013 | 09:17 AM
Club Wagon's Avatar
Club Wagon
Thanks will be taking a look, but F-150 only must turned 45,000 miles. Seems early even for these Lubed For Life ball joints,no?
Old Feb 24, 2013 | 09:21 AM
Club Wagon's Avatar
Club Wagon
Thanks, will be looking into this, but there's been no indication squeaking is associated with "turning the wheel".
Got "A grease needle" if I can find it.
Old Feb 24, 2013 | 02:26 PM
bricooper78's Avatar
bricooper78
My old 97250LD does that, it's under the rear, I'm not convinced it's not shocks, but it's WAY too cold to yank them off to test it lol
I'll know in the spring time if that's it or not, but post up what you find!!
Old Feb 24, 2013 | 07:44 PM
JWC 3's Avatar
JWC 3
No It does not look too early for them to fail . Depends on enviroment and use .
Old Feb 24, 2013 | 07:57 PM
Doc's Avatar
Doc
Mine had a LOT less miles than that when it started squeaking.
Old Feb 25, 2013 | 07:10 AM
TrdLtly's Avatar
TrdLtly
TreadLightly
Yup. My F250LD has the same suspension type squeak. Not annoying enough yet.... at least till Spring.
Old May 3, 2013 | 09:20 PM
Club Wagon's Avatar
Club Wagon
Thanks JWC 3 & Doc, family emergency delayed getting back to my evolving F150 squeak until this week. Did get several pros to listen/look at the problem, but nobody could confirm if it was top ball joint or shock absorber. Also slathered the suspension bushings in silicone.
Squeak became much more annoying, complaining on every little bump, but ball joints proved to be tight, boots in excellent shape, passed test in FORD shop manual. Got so EZ to squeak could demo by pushing bumper. Fact that it wouldn't squeak until it was bounced 2-3 times & at 1st only squeaked on rebound suggested shock. Finally disconnected shock & confirmed it was ball joint.
Schedule prohibits expensive, DIY suspension rebuild, but had brainstorm. Exclusively rural use means F150 rarely gets wheels turned lock to lock. Just for the halibut I decided to try to redistribute whatever Greased For Life lubricant was left inside the ball joints by steering lock to lock a bunch of times. The theory worked like magic, silencing the persistent squeak in just a few minutes!
Old May 3, 2013 | 09:47 PM
JWC 3's Avatar
JWC 3
Glad you found it . For the heck of it , find your grease needle . You may be able to put some more grease in them , Jack it up to unload the joints , and give them a few shots of grease . If no play ,and gentle use , you may buy some more time on them . Keep a close eye on them though ! Good luck !
Old May 3, 2013 | 10:27 PM
Club Wagon's Avatar
Club Wagon
"For the heck of it" I gave up looking for a grease needle in an away from home haystack & just bought another one. Am certainly "able to put some more grease in them" at this point, but would prefer not to puncture intact boots - now that ball joint is silent.
Posted the update in order to let FTE contributors know an EZ way to help diagnose what appears to be a bit of a ball buster symptom. Wasn't surprised that I was unable to pin point source of squeak, but none of the pros who took a whack at it could tell if the squeak was shock or ball joint either!
adamstewart7
1997 - 2003 F150
Jul 24, 2012 08:04 PM
sludges squaw
1997 - 2003 F150
Oct 4, 2006 08:21 PM
skilife17
1997 - 2003 F150
Jul 9, 2006 09:30 PM
spoon059
Jan 30, 2003 01:56 PM
Jim_V
May 20, 2001 11:15 PM
