Front End Creaks
Old May 20, 2001 | 10:08 PM
Jim_V's Avatar
Jim_V
Front End Creaks
I knew something was bnound to happen sooner or later,everytime I get a different car/truck something bad happens within a month.My `86 F150 is going on 2 weeks with me tomorrow and,today something in the right-front started to creak,mostly when I turn right.The ball-joint looks dry,but I can`t fit a grease gun in the tight space to grease it,so I squirted some 20w50 in it for now,but that didn`t seem to help.Anyways,I`m thinking it may need a ball-joint.I had planned to leave on a trip Wendsday and really need it fixed.Anyone else think of what else it "might" be? I`ve narrowed it down to right-front spindle area.
Old May 20, 2001 | 11:05 PM
PAUL_2's Avatar
PAUL_2
Front End Creaks
Usually a worn ball joint will cause more of a clunk , metallic sound , not saying that isnt the case with your truck , but the radius arm bushing on that side may be the cause of the noise . Jack the wheel & grasp the tire at top & bottom & try to rock the wheel , any play is usually the ball joints , but also check the wheel bearing for any play if you dont notice the ball joints moving . The right side radius arm bushing is susceptible to heat from the exhaust & it usually fails before the left side .
Old May 20, 2001 | 11:15 PM
PAUL_2's Avatar
PAUL_2
Front End Creaks
