Zero Gas Tanks
Old Feb 23, 2013 | 08:07 PM
FoundOnRoadDominatin's Avatar
Exclamation Zero Gas Tanks
I was so happy thursday. I took a sick day to work on the truck and finally after a year got her started. Engine sounds strong, all the lights work( except a small issue but I will post another thread for that) I felt satisfied.
But this was with me feeding gas to the carb with a funnel. So I decided to drop the tanks and check them out today. Rusted out from the inside and all the lines well rotted. Just great. So what do I do from here guys... do I just go to summitracing.com and buy a new tank..... your advice is much appreciated.
Old Feb 23, 2013 | 08:18 PM
Galendor's Avatar
Galendor
Yep. Sounds like you need to buy a new tank, sending unit (probably), and gas lines. You need a clean fuel supply to have a running truck!
Old Feb 23, 2013 | 08:58 PM
fiftyfordfloored's Avatar
fiftyfordfloored
Or try RockAuto... or your local NAPA and bring the print-out of the pricing on RockAuto and get a better deal and no shipping...
SPECTRA Gas Tank Part #s:
F6A - Side Mount (Mid-Ship) 19 Gal
F14A - Side Mount (Mid-Ship) 16 Gal
F1C - Rear Mount 19 Gal
Sending units (also Spectra numbers):
FG74A - Side Mount (Mid-Ship) 19 Gal
FG75A - Side Mount (Mid-Ship) 16 Gal
FG73A - Rear Mount 19 Gal
Hope this helps.
Old Feb 23, 2013 | 10:39 PM
Steven Conroy's Avatar
Steven Conroy
If you have some cutting/welding skills you could just make your own supersize tanks out of some 55 Gallon oil drums like an old Army buddy of mine did. Measure how deep the space between the bottom of the frame and your bed is, lay your drums on their side, mark from the ground up and cut. Weld a flat piece of metal to the side you cut, cut out the holes for your sending unit, return lines etc. rinse it out and mount. Depending on how much you cut you could have anywhere from a 40 to 50 gallon fuel tank. Have fun at the pump with that!!!
Old Feb 23, 2013 | 10:40 PM
Mediarocker's Avatar
Mediarocker
You can try LMC, they also have the rear mount tanks and extended run tanks.
Old Feb 23, 2013 | 11:55 PM
JayzDaddy's Avatar
JayzDaddy
Use the local part stores. No shipping and some sort of warranty available close by.
Old Feb 24, 2013 | 06:59 AM
Franklin2's Avatar
Franklin2
Yes, all the local stores carry them. What does that tell you? They also carry ignition tumblers, parking brake cables, etc. for these trucks. Check out your sending units also, they like to go bad.
Old Feb 24, 2013 | 10:59 AM
Yep everything was pretty much no use at all. But considering the price of two new tanks, lines, hoses, etc. I was wondering if I should just buy a bigger front tank and skip the rear tank but I soft of want to keep it the way it was supposed to be kept.
lbj
Jul 19, 2011 04:36 PM
e william
Aug 17, 2007 11:08 PM
txlegman
Jan 15, 2007 10:12 AM
rancherman84
Nov 8, 2005 12:39 AM
Mil1ion
Jun 18, 2002 10:08 PM
