AC wire diagram???
Old Feb 23, 2013 | 02:20 PM
Jay94250's Avatar
Jay94250
AC wire diagram???
Hi, I just recently picked an 85 f150 351 HO. The ac doesnt work, the ac compressor doesnt kick on, if I jump it, it does work. My issue is there is a lt green wire with a blue or purple stripe on it that comes from the switch on the accumulator and goes towrds the driver side of the engine bay, the harness tees off to the single light green wire w the stripe as described, and the other part of the harness goes to the compressor clutch. the green wire with the stripe in question has a plastic connecter end on it and is melted, where does this end go? I can't seem to find a wire diagram for this. Any help will be appreciated.
Old Feb 23, 2013 | 05:58 PM
Franklin2's Avatar
Franklin2
That wire went to a solenoid on the carb that boosted the idle speed when the A/C was running. Sounds like you are low on freon.
Old Feb 23, 2013 | 06:27 PM
81-F-150-Explorer's Avatar
81-F-150-Explorer
I have the diagram for the 1980 avaliable online and it is close enough for you to use.
The 1981-1986 is vitually identical except; Brown/Orange wire goes to F-15 in the fuse panel instead of F-14 as this diagram states.
Old Feb 23, 2013 | 07:13 PM
Jay94250's Avatar
Jay94250
thankyou for the wire diagram. I see that the melted end goes to the solenoid, I am atrating to think that my switch is no good or like you said about the freon being low. Im going to go get the ac maifold gauge set and check it.
Old Feb 24, 2013 | 07:20 AM
Franklin2's Avatar
Franklin2
I bet the switch is doing it's job. It's called a "low pressure" switch and I bet you have low pressure. This switch also controls the cooling, and cycles the compressor on and off when the evaporator gets cold. The colder the freon gets, the lower the pressure it has, so it naturally controls the cooling of the system also.
Old Feb 24, 2013 | 12:34 PM
Jay94250's Avatar
Jay94250
oh...I see. Thankyou for the info. I want to get the ac up and running before the summer comes lol
jason gressley
Jul 13, 2016 08:43 AM
kegger66
Jul 13, 2016 08:39 AM
Boz86
Jan 31, 2011 08:45 AM
rboeding
Oct 1, 2006 08:28 PM
