Squeak/scrape noise in drive
Old Feb 23, 2013 | 04:41 PM
02xlt3.0's Avatar
02xlt3.0
My '02 4x2 has developed this half scrape half squeak noise in drive. 140k, 55RE trans, all original drivetrain. It sounds like someone wrapped a wire coat hanger to the driveshaft. (No, I looked). It seems to be in sync with the speed of the shaft or wheels. U-joint maybe?
I'm stumped, and if I have to take it to a garage I'd like to have some clue what to tell them to look for. Any ideas?
Old Feb 24, 2013 | 06:45 AM
03 Maz B23's Avatar
03 Maz B23
Try jacking up rear end (block frt wheels) ,put it in neutral and see if can pinpoint it by rotating wheels by hand. Could be a dragging brake shoe/parking brake or rust on drums or drivetrain component. Has rear diff fluid level/condition been checked lately?
Old Feb 24, 2013 | 04:34 PM
Rangerman Stan's Avatar
Rangerman Stan
02xlt3.0, definately check your u-joints. The originals are sealed and they eventually go dry and start making metal dust that is rusty and make the rythmic scrape/squeak similar to what you are hearing.
Old Mar 8, 2013 | 10:08 AM
02xlt3.0's Avatar
02xlt3.0
Tried jacking it up and turning the rear wheels, which while a good suggestion wasn't the issue. Going to look at the U joints next.
Old Mar 8, 2013 | 10:52 AM
reddog99's Avatar
reddog99
It's easy to check. Just grab the driveshaft near each joint and give it a good hard shake. If you detect ANY play in the joint then it's bad.
danb7869
1997 - 2003 F150
Aug 22, 2011 09:06 AM
forman621
Bronco II
Jul 29, 2009 11:27 PM
SMarquez
Modular V10 (6.8l)
Jun 13, 2007 05:33 PM
jb3824
Sep 9, 2006 08:47 AM
nielmans'77
Mar 4, 2004 11:22 PM
