Differential Oil Temp ?
Old Feb 23, 2013 | 07:29 PM
mhoefer's Avatar
mhoefer
Mark, he is driving a F250 not a F550 so me thinks the GCWR will be significantly less, 23,500? Or so and as a result was thinking the temps will be quite a bit less unless he is actually pulling in Arizona in the mid summer heat, loaded up, which is unlike anything I have experienced. Your testing is pretty severe conditions so yeah, still thinking not much higher than 250 will ever occur. I am not an insincere, just a regular guy with lots of different real world experience in different equipment for 40 years. I think I am about done trying to contribute and going out partying with my lovely wife LOL.
Old Feb 23, 2013 | 08:28 PM
Curt's05's Avatar
Curt's05
Wiser by FTE
Would the 2008 fined cover work for this? They are about $50 at tousley parts depot
Old Feb 23, 2013 | 09:15 PM
MisterCMK's Avatar
MisterCMK
I'm sure you could tap a 2008 cover for a temp sender.
Old Feb 24, 2013 | 01:29 PM
diesel_dan's Avatar
diesel_dan
By the way, here are the part no's you need for the updated cover (and you need longer bolts since the alum is thicker)... Also I understand this cover will fit the front on the 4x4s -- doubt it needs it, but for looks...
8C3Z-4033-A COVER
6L1Z 4346-AA BOLTS X12
BP0fMD: Another advantage of the Magtec is extra fluid -- I can't justify 5x the cost though.....
Old Feb 24, 2013 | 02:43 PM
BPofMD's Avatar
BPofMD
Veteran: Navy
Has anyone EVER tapped a stock cover for a temp probe? I don't think the stock one is thick enough to do it.
The Mag is prettier!
Old Feb 24, 2013 | 02:57 PM
Bullitt390's Avatar
Bullitt390
Certified Thread Hijacker
1/8 npt shouldn't be an issue. A welded bung would make for more piece of mind.
Josh
Old Feb 24, 2013 | 04:12 PM
diesel_dan's Avatar
diesel_dan
A can of black spray paint and a few passes with a dremmel and the stocker would look purtie too
Old Feb 25, 2013 | 04:25 PM
diesel_dan's Avatar
diesel_dan
Thought I'd throw this in for you to consider: I emailed riffraff about if they carryed the'08 cover and Clay said they have their own now. It looks nice (black and alum fins), holds an extra qt. and has a drain plug! (where you could put your sensor). Plus they use a Vitron o-ring so no need for sealant.
Oh yeah and it's only $219.33... Check it out:
Riffraff Diesel: Riffraff Diesel Rear Diff Cover
Old Feb 25, 2013 | 04:26 PM
amdriven2liv's Avatar
amdriven2liv
I'm hitting easy street
Nice cover, just a little spendy for me.
Old Feb 25, 2013 | 04:37 PM
BPofMD's Avatar
BPofMD
Veteran: Navy
Thanks, but already ordered the Mag.......
Old Jul 22, 2013 | 05:29 PM
BPofMD's Avatar
BPofMD
Veteran: Navy
OK...finally have a "real world" answer for this. Just got back from a two week run up north to get cool from this Maryland "hazy, hot and humid" but the weatherman had different ideas! Was running up into PA on 222 & I-476 in close to 100* heat and saw temps on the rear end right up next to 200 degrees at the highest. After running about 2 hours normally, it stayed about 180 but in those mountain passes it got right at 200. It takes a while to get up to 180. If running below 2 hours, you probably will never get to 180 - unless you are in the mountains. In winter/cool weather it'll be tough to get it to 180.
I was surprised to see my coolant/oil temps stay within the recommended 15* spread even in the mountains. Going up they'd pretty much stay about 8-12* difference...even getting up to 230/235 but peak the hill and down the water temp would come with the oil following...but much slowly (Oh yes, the fan was screaming!). Running in the "not-so-high hills" those temps would always stay within that 15* spread - up AND down . I do have studs in the engine and the EGR valve is stock, as is the oil cooler. Running Shell 5-40 synthetic. (Rotella)
Old Jul 23, 2013 | 05:09 PM
BPofMD's Avatar
BPofMD
Veteran: Navy
Wow - NO comments?
Old Jul 23, 2013 | 05:53 PM
  #28
04badford's Avatar
04badford
that's good to know with the 180/200* far cry from 300 and I don't think the bearings would like that heat any way, not for very long are you thinking the new cover is running cooler or about the same temp? thanks for posting there's really no threads out there for this
Old Jul 23, 2013 | 06:01 PM
  #29
raptor131's Avatar
raptor131
I tried to rep ya, gotta spread some first. Do you have pics of the rear diff?
Old Jul 23, 2013 | 07:12 PM
  #30
BPofMD's Avatar
BPofMD
Veteran: Navy
