Starter issue
Old Feb 20, 2013 | 07:03 PM
BigBlockF350's Avatar
BigBlockF350
Starter issue
Went to start my truck this evening, and the starter seems to spin freely. It isn't engaging with the flywheel. Not sure if it's an issue with bad teeth, bad starter, or wiring.
My starter isn't too easy to pull off. It's tangled up in the header on the passenger side.
Any ideas on where to start?
My engine and truck info is in my signature below.
Old Feb 20, 2013 | 07:07 PM
powerstroke72's Avatar
powerstroke72
Moved to the 1987 - 1996 F150 & Larger F-Series Trucks forum.
Old Feb 20, 2013 | 09:07 PM
GNR22's Avatar
GNR22
Have you actually crawled under the truck to look at it? On my truck, the top bolt on the starter came loose and left the starter hanging back so it wasn't making contact with the flywheel. Perhaps something like that happened. In any case, you'd have to get a visual on what's actually going on.
Old Feb 20, 2013 | 09:25 PM
BigBlockF350
Yeah, I've looked at it. It's not loose.
Old Feb 20, 2013 | 09:30 PM
GNR22's Avatar
GNR22
Are teeth missing from the flywheel? have somebody turn the key so you can see what's really going on.
Old Feb 20, 2013 | 09:33 PM
Immortal_Ben's Avatar
Immortal_Ben
Could be the solenoid has gone out, and is not engaging the starter to the flywheel.
Old Feb 20, 2013 | 09:34 PM
BigBlockF350
I don't know about teeth on the flywheel. Never had any issues with anything like this or any starter noise while starting, so I doubt that's the issue.
Old Feb 20, 2013 | 09:35 PM
BigBlockF350
Possible. I believe the solenoid is on the inside of the passenger side fender in the truck. Sound right? How would I test it?
Old Feb 20, 2013 | 09:58 PM
GNR22's Avatar
GNR22
If the solenoid had gone out, would the starter still be spinning? I'm not sure, but I don't think so.
Old Feb 20, 2013 | 10:02 PM
BigBlockF350
I thought that one piece of the solenoid powered the spinning part of the starter, and another powered the "bendix" piece that pushes the gear out. I could be completely wrong.
Old Feb 20, 2013 | 10:09 PM
GNR22's Avatar
GNR22
Perhaps that's correct. I'm not sure. Every time I've had a solenoid go out, the starter neither spins, or pushes the gear out however.
Old Feb 20, 2013 | 10:16 PM
BigBlockF350
I had a solenoid go out once and the starter would pus the gear out, but not spin the starter. Ended up replacing the whole starter/solenoid assembly.
Old Feb 20, 2013 | 10:33 PM
BigBlockF350
Just looked at a replacement starter online, and it looks like only 1 wire connects. So, there is only one piece getting power to push the gear out and spin the starter. I'll check it out soon and see how bad it'll be to pull my starter off...
Old Feb 20, 2013 | 10:38 PM
GNR22's Avatar
GNR22
On my truck, there are only 2 bolts, one on top, one on bottom, and then the wire that goes to it. That's on a 351w though. It can't be much different.
Old Feb 20, 2013 | 10:46 PM
BigBlockF350
Yeah, even though my engine is a 73' (out of a lincoln), the starter is the same one that was on the 351 that was pulled out of the truck 15 years ago. Probably the starter was never replaced on the 351, which would make the starter 25 years old.
