OBS Engine Tear Down (PIC HEAVY)
Old Feb 20, 2013 | 04:11 PM
2000ca250's Avatar
2000ca250
Wait....where should the check valve be? Square hole on the left side of the block under the front cover? Or in the front cover....
Old Feb 20, 2013 | 04:56 PM
fordpride's Avatar
fordpride
I'm having a brain fart. Sorry for the mix up
On the 94.5-95 the drain back valve in built into the hpop
Square hole on the left should have a check vale in it coming from the mounting engine side of oil filter mounting head
Round hole on the right should have a valve to
Round hole with valve
Old Feb 20, 2013 | 05:21 PM
fordpride's Avatar
fordpride
Old Feb 20, 2013 | 05:28 PM
Bonanza35's Avatar
Bonanza35
I'm following this one also. Mike you need to fly up to ellenburg, to give a hand. Wish we all could. Great extra project. Wasn't it honed out once already if he reringed it?
Old Feb 20, 2013 | 05:31 PM
2000ca250's Avatar
2000ca250
Doesn't look like it was honed when the most recent set of rings went in. No crosshatch at all.
Old Feb 20, 2013 | 06:08 PM
aawlberninf350's Avatar
aawlberninf350
It's a Van Gogh
Thanks for posting up the pics! I get more out if this than diagrams.
Will a later front cover and hpop slap right on and eliminate the check valves in those locations?
Old Feb 20, 2013 | 06:53 PM
fordpride's Avatar
fordpride
Yes you can. If it was me I'd do that.
Old Feb 21, 2013 | 01:12 PM
2000ca250's Avatar
2000ca250
Yep. That would be the plan. Anyone have an opinion on what is on the pistons? This motor hasnt ran supposedly since the new pistons rings and rods were put in it. I'm thinking either ether or gasoline soaked rag was used trying to start it.
Old Feb 21, 2013 | 01:59 PM
fordpride's Avatar
fordpride
If its just soot that can be cleaned off I wouldn't worry about it.
Old Feb 21, 2013 | 02:04 PM
2000ca250's Avatar
2000ca250
It wasnt exactly soot. There were crystals in it, and it was hard. Didnt come off much when just wiped without brake cleaner, but with brake cleaner a lot of it came off.
Gotta pull everything out of it soon and get the block to a machine shop. Fresh Hone and acid bath are desperately needed.
96ford250
Feb 19, 2013 09:48 PM
Justin03PSD
Jul 4, 2011 02:51 PM
dustybumpers
Maryland Chapter
16
Aug 3, 2009 07:33 PM
ole_smokey_88
Oct 19, 2007 12:38 PM
