OBS Engine Tear Down (PIC HEAVY)
Old Feb 20, 2013 | 01:09 PM
2000ca250's Avatar
2000ca250
Alright guys,
figured I'd throw this up on here since its been awhile since I had a good thread over here. I also took a lot of pics and I know how badly everyone loves pics.
About a week ago I picked up a engine out of a 95. I know it has been rebuilt once, and most recently it was pulled out of a buddies truck, taken to a local mechanic for a "rebuild" because it ran away on my buddy and supposedly needed new piston rings. It never started up after this mechanic worked on it, my buddy (after 8 months) ended up just buying another motor, and wanted to get rid of this one, so I got a KILLER deal on it.
Anyways, here are the pics..
Got it all mounted up on the stand today. Working by myself made it a bit hard to get it completely square on the stand...
Here is how the engine looks on the stand, it is a complete grimey oiley ****ty mess...
I'll take some better pics of how bad the sludge build up on it is when I get some more time to get some of it gone...Started by pulling the fuel bowl and mechanical pump...if anyone knows anyone that wants or needs either part let me know, its theirs for shipping. Next I pulled the HPOP res and HPOP, gotta clean the HPOP up and send it off to Joey... Look what I found when I removed the res....
HOLY RTV!!!! who wants to take the bet that at least part of the problem is RTV stuck in the HPOP or IPR...
Underside of the Res...
Anyways, thats all for today as far as that engine goes....did that while my coolant was draining so I could swap my water pump....
Old Feb 20, 2013 | 01:11 PM
2000ca250's Avatar
2000ca250
So far I have all injectors removed, cleaned the engine down a bunch, pulled LPOP, and pulled the Water Pump. Waiting on everyone's comments before I pull the heads and flip the motor and pull the pan. I've been debating on whether or not I want to pull the heads off, but given what I've seen so far, I kind of want to pull the heads off and strip this motor all the way down. As Bryan pointed out, gaskets are cheap compared to not knowing what exactly has been done. After seeing some of the work that this guy did on this motor, I feel like I need to tear it apart completely to see if he did ANYTHING the correct way and not half assed.
That being said, lets get on to the pics...
(I'm just gonna upload all of the ones I have, sorry if you dont have a good connection, theres a TON of them)
Popped the VC's, I have individual pics of all the injectors if anyone spots anything strange, but I'm not gonna clog up this thread with all of them.
Drivers side
A mix of injectors, assuming this is just because they were reman supposed stage 1's. Guess Evan is gonna sell them to a kid whos gonna send them off to be gone through, I was kinda hoping he'd sell them to Mike so that we could all find out what was wrong with them.
Passenger Side
2000ca250's Avatar
2000ca250
Whole side was AA injectors (or at least AA cores)
Moved on to cleaning the engine some more, went through 2 cans of the heavy duty foaming degreaser...
Before:
During:
After:
Found some more RTV where I dont think it should be...
Interesting to find electrical tape on the UVCH...wonder if its covering up a butt connector...
Old Feb 20, 2013 | 01:12 PM
2000ca250's Avatar
2000ca250
More unneeded RTV....Seriously starting to think that Grey RTV is to Peurto Rican's what Duct Tape is to Rednecks...
Pulled the Harmonic Balancer, came off really easy with the Impact...
Pulled the LPOP
Old Feb 20, 2013 | 01:14 PM
2000ca250's Avatar
2000ca250
Can anyone see any markings on the LPOP? I double checked it now that its on the bench and cant see any on either side...not really sure what that means...
Stripped the Front Cover..
Dont judge the chair in the background...mostly for my dogs when they chill in the shop/garage
More RTV
Pulled the Oil Rail Plugs to verify that there was no RTV in the rails...
2000ca250's Avatar
2000ca250
More RTV
Old Feb 20, 2013 | 01:15 PM
2000ca250's Avatar
2000ca250
More pics of the crank...
Cylinder Walls..
Old Feb 20, 2013 | 01:16 PM
2000ca250's Avatar
2000ca250
Here are the pics from when I removed the heads....More of the same...also guessing the soot and discoloration is from ether/starting fluid in the guys attempt to get the thing to start...
Drivers side
Old Feb 20, 2013 | 01:17 PM
2000ca250's Avatar
2000ca250
Passenger Side
Random pic of the cylinder wall
Front Cover removed
Let me know what you guys think. Right now its just sitting on the stand as just the block with the rotating assembly in it. Still want to figure out why it didnt start....
Old Feb 20, 2013 | 01:44 PM
BigAlsPSD's Avatar
BigAlsPSD
Nice job, Palmer, looking forward to following this one. All stuff I enjoy!
Old Feb 20, 2013 | 01:47 PM
2000ca250's Avatar
2000ca250
Thanks Alan.
Looking for a good machine shop that knows what they are doing with these engines and going to hopefully just get it honed and cleaned up. Then balance the rotating assembly, get the pistons machined, and rods cryoed, probably throw a rebuild kit on it and keep it as a spare.
Old Feb 20, 2013 | 01:56 PM
2000ca250's Avatar
2000ca250
Just realized I had a double post earlier.... heres the post that I meant to have in there.
I pulled the pan, front cover, and heads...here is what it looked like...
Got the pan off to find this little beauty...
Pulled the pick up foot, and unless I'm wrong it was missing an O-Ring where it attaches to the front cover...
Here are some various shots of the Crank
[/QUOTE]
Old Feb 20, 2013 | 03:04 PM
fordpride's Avatar
fordpride
The 94.5-95 have a different front cover then the 96-03
The 94.5-95 have a check valve (anti drain back)built into the hpop. If it was lost then it will never start.
There also two more check valves built into the oil filter head on the oil cooler. If one of them fail out it won't start
Old Feb 20, 2013 | 03:09 PM
2000ca250's Avatar
2000ca250
Mike,
In the pic of the front cover, do you see said check valve? I did not see it, but also not POSITIVE on where I'm looking or where it should be.
Other question I have, can anyone tell if this is for sure a 95 front cover vs the later years front cover? I know the engine has been rebuilt before, so I just want to verify that the front cover is the original
Old Feb 20, 2013 | 03:28 PM
fordpride's Avatar
fordpride
Square hole on the left should have a check vale in it coming from the mounting side
Round hole on the right should have a valve to
Round hole with valve
