Sponsored by: Real Truck
Coolant leak
Old Feb 19, 2013 | 05:52 PM
jmconneely's Avatar
jmconneely
Coolant leak
I have a small coolant leak on my 7.3, I kinda thought it could be a bad seal on water pump or seal around it. Someone said today that the 7.3 has a pressure relief type deal that releases water due to pressure build up. Is he full of s or is there a chance he knows what he is talking about?
Old Feb 19, 2013 | 10:55 PM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
Is your leak coming from behind the water pump pulley? If so its time for a new pump.
Maybe your friend was talking about the weep hole.
Old Feb 20, 2013 | 05:52 AM
redford's Avatar
redford
FTE Leadership Emeritus
Most vehicles release coolant when too much pressure builds up. Aside from air cooled engines, I cannot think of a vehicle that does not have some sort of pressure relief in the cooling system.
Old Feb 20, 2013 | 09:42 AM
jmconneely's Avatar
jmconneely
I see some coolant up near the water pump. Not a lot but it is wet.
Old Feb 20, 2013 | 10:47 AM
jeffreyt's Avatar
jeffreyt
I'd first recommend checking to make sure the thermostat housing is not leaking, then also checking to make sure the tank isn't cracked.
Old Feb 20, 2013 | 04:05 PM
jmconneely's Avatar
jmconneely
Thanks for the advice everyone.
VaFordman26
Apr 14, 2014 09:58 PM
65F100390
Nov 5, 2010 04:53 PM
78f3504x4
Jun 3, 2010 10:05 AM
SouthernBlues
Jan 24, 2009 04:03 PM
JUMBO_UTE
Feb 8, 2006 04:32 PM
