Coolant Leak
Old Jan 23, 2009 | 07:15 PM
SouthernBlues's Avatar
SouthernBlues
Coolant Leak
I am leaking Coolant,looks like it is coming from behind the front pulley. Could it be the water pump and if it is how hard is it to replace.
Old Jan 23, 2009 | 08:03 PM
Old93junk's Avatar
Old93junk
Look underneath and see if its coming out of the small "weep" hole on the underside of the water pump. If it is, a new water pump is in your future. Not a big deal to replace, couple hours.
Old Jan 24, 2009 | 01:52 AM
rijrnnr's Avatar
rijrnnr
Be careful with your diagnosis...I saw water that looked like it was coming out of the pump, replaced it, and water was still coming out...out of the front freezeplug.
Old Jan 24, 2009 | 08:55 AM
jemini's Avatar
jemini
As was suggested to me a few weeks ago when I had a coolant leak, have the system pressure tested at a radiator shop or rent/borrow a pressure tester ( I got mine from Auto Zone). It took 5 minutes and the leak location was absolute. In my case it was the timining chain cover -where the coolant ports go through.
Old Jan 24, 2009 | 09:35 AM
jr32560's Avatar
jr32560
well put a pressure test will tell the tale
Old Jan 24, 2009 | 11:37 AM
MustangMatt96GT's Avatar
MustangMatt96GT
thats a possiblitly, but probably not the case in this instance... way to check for that would be take your oil cap off and see if you have condensation on the top of the outlet, if you do, you have oil and antifreeze mix, indicating bad headgasket, or bad timing cover gasket.
But weep hole sounds like it may be the case on this one, but do look at the pmp first before you start tearing it all apart.
Old Jan 24, 2009 | 02:46 PM
SouthernBlues
Thanks for all of the info, i found the leak. The thermostad housing has a crack in it
Old Jan 24, 2009 | 04:03 PM
quicklook2's Avatar
quicklook2
coolant pressure test is the best way to start.
if you would have replaced the pump and that did not solve it, you would have been pissed.
