quick question on pulling out 360fe
Old Feb 19, 2013 | 12:13 PM
FordmanShane's Avatar
FordmanShane
Before I go and pull this engine out do I unbolt the motor mounts that bolt to the frame?
Old Feb 19, 2013 | 12:24 PM
elkarcher1716's Avatar
elkarcher1716
No there should be rubber mounts that bolt to the engine and then they bolt to the engine perches. The engine perches bolt to the frame. You dont need to unbolt them.
Old Feb 19, 2013 | 12:32 PM
AK FORD GUY's Avatar
AK FORD GUY
When I pulled my current 360FE out of a 1974 F100 4x4, I left the perches on the frame and just unbolted the single nut from the stud that goes from the (rubber) engine mount to the perch.
Old Feb 19, 2013 | 12:46 PM
hickory1991's Avatar
hickory1991
X2 what AK said. Two nuts and it's loose. Are you pulling engine with transmission. If so will need to unbolt trans from crossmember, then lift trans a little and move crossmember.
Old Feb 19, 2013 | 01:31 PM
FordmanShane
Thanks.. the transmission is staying in
hergorilla
Oct 14, 2009 05:37 AM
menzfamfour
1978 - 1996 Big Bronco
Apr 29, 2008 11:11 AM
go2toa
Engine Swaps
Dec 12, 2005 01:34 PM
Greywolf
Apr 24, 2002 06:19 PM
rick
Dec 5, 1999 08:57 AM
