120 volt outlets?
Old Feb 22, 2013 | 10:12 AM
Alex from GA's Avatar
Alex from GA
I forgot to finish. If you tap in before the regulator.
Old Feb 23, 2013 | 01:58 AM
mkbrown's Avatar
mkbrown
drill
Copy that Alex. Thanks.
Old Feb 27, 2013 | 12:43 AM
mkbrown's Avatar
mkbrown
close to a wrap
So while crawling around under my 72 during my engine swap I looked more closely at my wiring remnants and see that indeed there is a tab that clearly used to hook up to the alternator. The wire is really well protected with a heavy woven insulation around it and what looks like two fuse blocks or breakers attached right near where it should be attached to the alternator. The wiring looks very expensive and is certainly long. Factory option or common aftermarket upgrade? How many volts does an alternator put out (I know it's a range) before the voltage regulator? I'm guessing here but this wire would run from the positive side of the alternator and then the body of the truck would serve as the ground for the outlet? I might just hook this baby up after I chase the wiring completely to make sure I don't have a dead short anywhere. Cheers.
tommyleea
Mar 6, 2019 11:03 AM
Curated Content Editor
Feb 26, 2019 02:35 PM
SCFlareside
Jun 27, 2015 09:22 AM
Freightrain
Aug 1, 2012 04:00 PM
cosmaar1
May 29, 2012 01:26 PM
