Ford Excursion 2002 HELP
Old Feb 18, 2013 | 08:44 PM
Zombie Hunter's Avatar
Zombie Hunter
New to forum, hopefully I am posting correctly.
My question is about my 2002 Ford Excursion 5.4 v8 Triton complete tune up done last 8/2011 when I bought it used with 98000 miles. As of Saturday it was running like a champ that afternoon it started to hesitate as I accelerated and some what starting jerking, after a few minutes it returned to normal, i did use a gas station i normally don't use. For the past 2 days it continues to occur at different speeds and accelerations. So today, I took my King of the Road to my mechanic and after a couple of hours in the shop, they called and told me they couldn't find anything wrong. It was hooked up to the computer no codes, drove fine, engine idle normal. Please help or advice. Thank you.
Old Feb 18, 2013 | 10:34 PM
AzSuperDuty's Avatar
AzSuperDuty
Intermittent problems like you describe can be maddening to try and sort out.
The problems you speak of, are they all accelerating or under heavy load?
If so might want to check your fuel filter. Change it... and take the filter and dump it into a pan and examine what comes out the input side of the filter.
Old Feb 18, 2013 | 11:16 PM
Immortal_Ben's Avatar
Immortal_Ben
Could have been water in the fuel. Try some HEET.
Old Feb 19, 2013 | 05:20 AM
jspence105's Avatar
jspence105
I don't know much about the gas Ex's but what your describing sounds exactly like the problems I had when I had bad coil packs on on my windstar.
Old Feb 19, 2013 | 10:15 PM
Zombie Hunter
Thanks for the advice, drove it today for a little bit and ran fine...thanks Ben I bought some HEET so will see.
Old Feb 19, 2013 | 10:56 PM
Immortal_Ben
Yer welcome, man. I try to be helpful once in a while around here.
its a ford thing 131
2004 - 2008 F150
Apr 2, 2018 11:14 AM
rustytruck77
1997 - 2003 F150
Jun 5, 2010 10:22 PM
Crazy-Man
Aug 24, 2007 07:35 PM
Big Sky
Modular V10 (6.8l)
Jan 21, 2005 09:51 PM
OAGES
Feb 20, 2004 09:38 AM
