What should i do while im changing the coolant?
Although i am cheap i am restoring this truck for me to take to college in the fall. I dont mind putting money into it just as long as it is money well spent and will make the truck more reliable and safer for me to drive on the road.
Water pump?
thermostat?
coolant hoses/lines?
Would you bother since everything seems to be working?
thanks!
I'd also take the belts off and spin the water pump by hand to "feel" the bearing, and see if there's any slop. I'd probably do the thermostat. (that one's too much of a temptation for Mr. Murphy...)
as for coolant, 7.3s need a coolant with SCAs - an additive to prevent cavitation, which is a nasty problem. you're in a 6.9, so while its not required it is wise to have. do a search and you'll have plenty to read on the subject.
if it were mine at this point, i would probably just flush it out good and roll with it.
To do a thorough job of getting all the old stuff out, pull the drain plugs located on either side of the block. Many replace these with pet***** to make the job easier the next time, though I didn't find removing them to be a big deal.
Mike
Mike
1. Let the system completely cool, like ice cold.
2. Remove rad cap
3. Drain radiator.
4. Drain block by removing plugs (one on each side). IIRC, they're 9/16" head hex and look like a bolt sticking out from the block (brass). The driver's side one is kinda near the oil filter; the passenger side plug is basically in the same spot on the opposite side.
5. (Optional) Plug everything back up and fill with a mix of water (tap or distilled) and whatever flushing agent you choose. There's a bunch of different stuff on the market, and even more 'old tricks' like dishwasher detergent. Run the flush for however long the instructions say. Some recommend idling in the driveway for a bit. Others recommend running with the flushing agent for a week or so. Just know that if you live in an area that can freeze, a lot of the flushing agents don't contain any sort of antifreeze like you'd normally run, so plan accordingly.
6. (Optional) If you're super ****, re-fill with tap or distilled water to flush. Repeat as many times as you feel necessary. The color and condition of th6 fluid coming out should be your guide.
7. (Optional) Pop the hoses off the heater core and flush with tap water. If it acts like it's backed up, now may be a good time to replace.
8. Drain everything again
9. Now'd be a good time to replace whatever it is you're going to replace since the system is empty (e.g. hoses, thermostat, heater core, etc).
10. Fill 'er up with whatever coolant you choose, but make sure it has some sort of provision for SCAs to prevent cavitation. I use FleetCharge because I can buy it locally at O'Reilly and I mix it with distilled water. You'll need 4 gallons of coolant (mixed with 4 gallons of water for 8 gallons total).
Filling the system can be a bit of a pain because you need to have patience to wait for the thermostat to pop open. There are techniques to get around this (like filling the block through the heater hose nipple or the thermostat opening), but I do it the easy way. Close everything off, then fill the radiator until the cores are covered (should use about half of the 8 gallons). No need to fill it all the way because it'll burp itself and inevitably make a big mess. Now fire it up with the rad cap off and wait..........and wait......and wait. Seriously, this can take a while. But eventually, the coolant level will start to drop and FAST. Keep the rad more or less topped off (at least have the cores covered). You'll get a lot of 'burps' from the system coming through the rad cap opening. This is perfectly normal. Once they stop, top off the rad and pop the cap on. Throw some coolant in the overflow tank (about 1/3-1/2 full) and you're done. DO NOT TAKE THE RAD CAP BACK OFF UNTIL THE SYSTEM COOLS OFF NO MATTER WHAT!! Even if you 'just' put the cap on, the system will pressurize almost instantly. Nothing like a boiling hot coolant geyser to ruin your day.
Some would tell you to drive the truck a bit to speed up the wait for the thermostat. I don't recommend it if you drain the block because you're essentially driving around with the system only half full. It'll overheat in no time. I got impatient with mine and tried to do that. I made it to the end of my block before the temp gauge spiked. The thermostat had opened and the radiator had completely drained itself into the block in just a minute or two. Instead, I recommend waiting it out. If it's real cold where you are, throw a piece of cardboard over the radiator fins to help speed it up, but otherwise just be patient.
Mike
duralast new vs valucraft remanufacturer? with a name like valuecraft.... lol
Mac.
You say you don't mind investing abit of money into, as long as it goes for something good, well then re-do the entire cooling system. I did it in my van not long after I got it.
I had no real history on it, and I go on long trips with it, and I personally like piece of mind instead of carrying a ton of parts with me.
I flushed out the rad and block, did the water pump and thermostat and hoses. The thermostat looked nearly new, but replaced it anyways and kepted the old one as a spare. Also installed a real temp gauge!
My '94 F150 I bought a while ago as a winter truck, I also re-did the whole cooling system.... (rad, hoses, thermostat) except the water pump, and well, it left me stuck overheated on the side of the highway on the coldest day of the year, -15*F at 7am heading to work. Water pump failed.
Just because is working fine now... doesn't mean it's any good for god knows how long.
