E4OD ECM relay
Old Feb 18, 2013 | 07:53 AM
halaferd's Avatar
halaferd
E4OD ECM relay
I'm having an issue w the relay for te ECM on my 1991 E4OD. I replaced it a couple months ago and yesterday it began failing again. If I remove it and then reinstall it, the problem remedies.
I am checking wires for shorts or bad spots this afternoon. Just wondered if this was a problem others have had.
Thanks
Old Feb 18, 2013 | 05:37 PM
batchman's Avatar
batchman
Haven't head that exact problem yet but sounds like a bad connection if re-seating it cures the issue.
I like Deoxit to clean up old connections but it won't fix everything.
Good luck,
- Jeff
Old Feb 19, 2013 | 05:44 PM
halaferd's Avatar
halaferd
I cleaned and used elec connection grease but that does seen to be the issue (not consistent either)... Oh well a little time and problem solving will cure it. Thanks for the response tho
50monte
Sep 29, 2015 08:47 PM
Greg5OH
May 9, 2012 04:28 PM
mudbogger93
28
Oct 23, 2011 12:33 AM
1bigjoe
Feb 11, 2010 12:53 PM
crazy_driver
22
Nov 9, 2005 06:27 PM
