07 6.0 HEAVY MODS. NEED INPUT
hey guys. I got a 07 6.0. Its studded,deleted and all that. Air Dogg 2, regulatedreturn,banks techni cooler. A bunch of stuff. Anyway this this thing runs fine but it cuts out itermittily. It idles great not a missing injector. Like a steady idle then like all 8 injectors just cut out. Then idles fine. No pitch change. No nothin. This happens about evry 5 seconds. Its gotta 58v innovative ficm. So thats new. Casserly 190s, so thats new. Turbo is a secret...shhhh. So thats new. Tanks been dropped,cleaned and wat not. ... No codes. One thing though. I cant get the altenator to charge the batteries.
Yes cheezit,i went against wat u said. Ill prolly pay for it later on. I just couldnt pass up that kinda money.
Any ideas
Any ideas
Man i inspected every centimeter of that harness. Its almost new. Do u think a connector might be loose? No,that wud throw a code. Wtf! That fuel might be the issue.
Its not a miss though. It idles like a dream. It just cuts out for maybe half a second. It does it every 7 or 8 seconds. Somtimes it idles great for 5 minutes. Then starts cuttin out. Like i say,theres no change in the sound/pitch of the motor.
DashBoss, SG2 or AE would be a good start to getting data.
Josh
Josh
Can you monitor the fuel pressure? And what is "cutting out" anyway? You say that it's like all 8 injectors stop, but with no change in the sound/pitch of the engine? Two things kinda contradict each other. You need to get a way to read the cylinder contribution at the very least, also from what I understand the 58v FICM's are quite prone to failure compared to standard voltage ones so I would suspect that unless you can monitor it in real time (I also understand that you can't monitor that properly with an OBDII gauge).
Sorry guys. I failed to mention. Im the owner of Dew-It diesel performance. I specialize in the ford diesel line up. I own a snap on modis,verus,AE and not mention this truck has a sct livewire. The pids suck. But good enuff for the masses. I get on fte to get insight. Maybe somthin i missed. 1000 minds are better than one. And...after all,im human.
So anyway,no....there are no codes. Power balance test passes. BUT! There is a test that didnt pass.....the vgt boost acuation test. I cant get the vanes to open. This is a problem guys. This turbo is expeirimental. With a 1 of a kind wheel. Capable of 750HPs.. Back to the drawing board huh....
Ohh yea,matt at innovative does all my tuning. its the vgt in the turbo. I did a test on it last night. Its not doing its job.
Awwight guys. We got the turbo tore down and the bar that moves the vanes was stuck. Garret had a revision and went from teflon to just steel. On a high hp truck it wont work. So were going back to the old teflon coated deal. Ill post pix if i can figure out how....thanx guys
