Wire gauge
Old Feb 16, 2013 | 06:25 PM
Labhound's Avatar
Labhound
Wire gauge
What is the best size cables to use for the starter system, from battery to solenoid, starter and ground? Would a gauge too big need more volts to get it to crank?
Old Feb 16, 2013 | 08:03 PM
BaronVonAutomatc's Avatar
BaronVonAutomatc
I believe the factory cables are 4 AWG. I had NAPA build some custom cables that are 1/0 AWG and they work fine.
Old Feb 17, 2013 | 05:24 AM
tiap's Avatar
tiap
Bigger the better.
I make my own from #1 welding cable and swage/solder/shrink copper ends to them.
Ground should be same size, you can't have too many.
I use copper antisieze on all the connections.
Old Feb 17, 2013 | 09:19 AM
Labhound's Avatar
Labhound
I was just wondering, to rule out all possibles. I do need to go through the diagram and make sure it's all correct. Thanks.
Old Feb 17, 2013 | 08:14 PM
Wyowanderer's Avatar
Wyowanderer
If you're of a mind to build your own, use welding cable in the appropriate size (I use #2). It has better insulation that takes higher temps and has many more individual wires which carry more amperage.
Old Feb 19, 2013 | 03:05 PM
grnlzrd's Avatar
grnlzrd
I've been thinking about relocating the battery, and was considering welding cable for the project. Where can welding cable be purchased? Internet sources?
Old Feb 19, 2013 | 06:21 PM
fmc400's Avatar
fmc400
MSEE
You should not solder battery cable terminals. Battery cables put a decent amount of leverage on the terminal, which can break the joint. Crimping the cable instead allows it to flex; and this is how store-bought cables are built. The proper way to build battery cables is with a crimper designed just for that purpose.
bakerbuilttracks
20
May 23, 2024 07:56 PM
ModernLife
Jul 19, 2015 07:19 AM
berick
Jul 31, 2012 09:09 AM
drewdole
16
Mar 28, 2010 09:56 AM
ford390gashog
Electrical Systems/Wiring
Oct 16, 2004 04:42 PM
