Where does this tube go?
Look at the exhaust manifold near the #5 cylinder. The part in the photo was likely attached to the top of the exhaust manifold and then attached to a port near the top of the carburetor. Originally, the rubber tube was red in color.
On the bottom of the exhaust manifold [opposite the top tube] is another metal tube which goes to the choke housing. This tubing should have a light colored [white] insulating sheath.
The purpose of this system is to provide heat to the choke bimetallic spring which parallels the warm-up cycle of the engine. On the 1984, there also will be an electrical wire going to the choke housing. There is an electrical heater inside with the bimetallic spring which receives it current from the "S" stator on the alternator. Clean filtered air is provided through the port at the top of the carburetor and is drawn to the choke by a small vacuum port inside the choke housing. This air is heated by passing through a tube in the exhaust manifold. The air does not mix with the exhaust gasses. With the tubing disconnected, as yours is, non filtered air is being drawn into the choke and mixing with the incoming charge.
It is not uncommon for these tubes to rust through... after all, your truck is almost 30 years old!
There are repair kits available in the "HELP" section of most parts houses for less than $15. It will be listed as something like choke heater tubing repair kits. Talk with someone older than 50, behind the counter. Many younger employees do not know what a carburetor is, much less how to repair a choke!
Good luck!
Good luck!
Dorman® Help!® 76850 - Choke Heater Tube Kit | O'Reilly Auto Parts
Seems like this aught to do the trick. RIght? I think in truth a lot of the young guys like me (21) like carbys for some reason .
