custom nerf bars
Old Feb 15, 2013 | 03:01 PM
JUSTICE1736's Avatar
JUSTICE1736
custom nerf bars
i was wondering if anyone had customized a set of nerf bars to fit on these trucks. i really like the look of the nfab with the hoop step, but unfortunatly they dont make anything that will come close to fitting our years of trucks. so i was thinking bout measure and just getting something close, but i hate to spend 400 bucks on something just to hack it up. so if anyone has made any could u post some pics or if you have custom made any kind of rocker slider or step for your truck. thanks!
Old Feb 15, 2013 | 05:03 PM
Behemoth's Avatar
Behemoth
I was doing the research into making a custom set of wheel to wheel nerf bars for my truck, but by the time I figured out that it would be over 2 grand to make them (stainless is spendy.....then add welding, polishing, etc.), I bagged the idea in favor of something simpler. I'm actually ok with just having a single step, as it keeps the truck looking simple, which is part of what I was after. I may again look into making a set, but it'll be a while before I pull that trigger.
Old Feb 18, 2013 | 06:22 PM
blacktundra10's Avatar
blacktundra10
I just got through putting some n-fab stainless steel nerd bars with steps onto my 75 f250 4wd. I can't remember the part number from n-fab, but they are the ones for the new f250 trucks. I had to weld the 3 mounting tabs to the weld plate on the truck then weld a kicker over to the frame at each of the three tabs. My truck has a 2" body lift and 35's and you can't see the kickers. They look sweet. I would post a pic but its at the shop
Old Feb 18, 2013 | 06:56 PM
blacktundra10
Note: I should mention that my truck is a crew cab. I don't know how that will affect your decision....
Old Feb 20, 2013 | 04:47 PM
JUSTICE1736
thanks for the info tundra. but unfortunatly mine is a regular cab. i guess i could try to use a crew cab or super cab set then id just have a step for the bed. but id worry bout the flex between the cab and bed.
al3x
Aug 27, 2009 12:27 AM
TexasXL
2004 - 2008 F150
Feb 2, 2009 12:16 PM
ALAN_50501
Appearance & Dress-Up
May 9, 2007 07:22 PM
Strobengh
2004 - 2008 F150
Dec 7, 2006 07:36 AM
Ken2600
Feb 19, 2003 12:01 AM
