messed up dearly
Old Jan 15, 2007 | 05:22 PM
knapikmichael's Avatar
knapikmichael
messed up dearly
i didnt mark my trannny lines when i pulled them off which one goes where or does it matter im gonna run a double tranny cooler with two fans one cooler is already in i have to get the other one and connect to it so matter or dont matter
Old Jan 15, 2007 | 07:51 PM
2jhanna's Avatar
2jhanna
I don't think that it matters which cooler is first or which dirrection the fluid flows through the coolers.
Old Jan 15, 2007 | 09:33 PM
roamer37's Avatar
roamer37
you want to have the trans fluid go through the original cooler in the rad first then to the other filters. Otherwise you will cool the oil then rewarm it in the radiator.. the cooler line closest to the front pump in the trans is the pressure line..
Old Jan 15, 2007 | 09:38 PM
PLC7.3's Avatar
PLC7.3
The outlet pressure line (trans front) goes to the rad drvrs side, the rad pax side goes to the aux cooler then back to the rear line of the trans.
Old Jan 16, 2007 | 06:46 AM
knapikmichael
ok ill check but i think the guy that owned the truck before did away with rad cooler thats why there was an extra tranny cooler
