Mods so far...What next?
Old Feb 15, 2013 | 11:29 AM
ML190's Avatar
ML190
Picked up my 2001 V10 4x4 with 83k miles last month. I knew when I got it that it needed "Something" done to the front end. It drove like hell all the way home, wandered all over the road and made a terrible banging noise. The guy I bought it from had just put $500 worth of shocks under it to fix this and it did nothing. Anyway, after about 30 seconds of looking under it I saw that the swaybar endlinks were trashed. Ordered and installed those, noise was gone, it drove way better but still had the wander issue.
Next step was to spend a couple of hours on this forum...That led to the next plan of installing a Hellwig rear sway bar. That helped alot also but not 100%. Searched the forums some more and found the "Steering box adjustment" thread. That helped even more. The truck drives way better but still not perfect. (I realize a four ton beast will not drive perfect, but I think it should be better)...
So my next step will be to find some V and B code take-offs from an F250 and get the suspension even stiffer. Any other ideas? Air suspension maybe?
Thanks for all the help so far...That search button is awesome.
Old Feb 15, 2013 | 11:53 AM
Stewart_H's Avatar
Stewart_H
Make sure your hubs, ball joints, and tie rods are all in good shape and working well.
You can read more here: https://www.ford-trucks.com/forums/1...l#post11373753
Also, what kind of tires do you have? Size? Rating? PSI?
Stewart
Old Feb 15, 2013 | 01:40 PM
ML190's Avatar
ML190
Stewart
I'll have to check when i get home...but they're some made in China off brand 4 ply with around 65 psi.
Old Mar 3, 2013 | 05:12 PM
ML190's Avatar
ML190
Sorry for the delay...
Tires are Concourse, load range E, I've tried them at 55 and 65 psi with no noticeable difference.
Had the tires rotated when I had the oil changed, still the same. Myself and the mechanic checked the front end and could find nothing wrong. (only 84,000 miles, not much worn yet)
It's looking like the B-Codes are the next step. Hope that will keep the rear axle from twisting.
Thanks again
Old Mar 3, 2013 | 05:29 PM
EXv10's Avatar
EXv10
Mine tracks like a freight train at 160K miles...........check your toe in.
Old Mar 3, 2013 | 05:54 PM
ML190's Avatar
ML190
The friend of mine I bought it from said it's always driven this way, even after having it aligned. He also said his 05 Limited drives the same or worse.
I'm going to run it by the tire/suspension shop in a couple of days to see what they'll charge to install the springs, I'll have the alignment/toe-in checked while I'm there and report back.
The thing wants to drive straight but what should be minor corrections with the steering wheel seem to get bigger and bigger. (not sure if that makes sense) The addition of the rear sway bar helped with body role and as a result diminished the need for a lot of the steering corrections. But wander is still a problem.
My dad has a 2000 F350 4x4 farm truck and it drives just fine with around 160,000 miles. I'd be happy if my X drove like his farm truck.
Old Mar 3, 2013 | 06:08 PM
EXv10's Avatar
EXv10
Something wrong with it...........maybe the tires too.
Old Mar 3, 2013 | 06:20 PM
Immortal_Ben's Avatar
Immortal_Ben
The wander is something we see all the time and discuss til blue in the face.
Old Mar 4, 2013 | 09:31 AM
ML190's Avatar
ML190
I like this X too much to let the wander issue drive me insane. I'm determined to win.
Took it by the shop today to get a quote on installing springs all around. If I provide all the parts they'll install all four springs and realign it for $375.
Now to find the V and B codes.
Old Mar 4, 2013 | 09:48 AM
Immortal_Ben
I would be OK with that labor quote.
Old Mar 4, 2013 | 09:54 AM
ML190's Avatar
ML190
I really didn't know what to expect when I took it by there. It seemed to be a fair price, plus I'll have someone besides myself to blame if something goes south. They do pretty good work so it should go fine.
Old Mar 4, 2013 | 10:53 AM
RobRoss's Avatar
RobRoss
If your lower ball joints do not have grease fittings, you can drill and tap. I did that to my 05 Ex and it helped the wander the most (I also adjusted the steering box and alignment). V/B's may be next...
bedwar4
2004 - 2008 F150
Aug 19, 2018 08:26 AM
kefrko
Mar 31, 2015 07:14 AM
lariat79sc
Apr 9, 2012 09:37 PM
DogDoc94
Nov 29, 2011 10:24 PM
Godfather15228
Sep 5, 2010 09:00 PM
