It can. This conversion is alot of work. I have a 76 f350 SC dually 2wd that had a small engine fire but the body and paint is showroom condition. I've thought about putting the running gear out of my highboy under and putting a cummins in it. Making it the ultimate work horse and selling my V10 Super Duty.
4X4 crew cabs of the highboy era are also considered to be highboys, they share the very same platform as a regular cab highboy, i.e. 34" wide frame, low pinion front axle, divorced transfer case, power assist steering, in-cab tank, tall factory ride height, etc.
Sorry to be so specific but where I'm from everyone thinks just cause they have a pre 80s ford it's a highboy.
I can't even count the number of times i've seen a "highboy" listed on Craigslist only to click on the ad and see it's a lifted F150.
Yes, it may sit "high" and its gender may be a "boy" but it's not a "highboy", i try to explain it to them and most get defensive and try to school me on why their truck is a highboy, i usually hang up the phone at that point.
My plan was to convert it, my buddy has a 73' highboy that I was gonna take parts off of. I was just gonna do a 4in lift but decided not to cause i would go through u joints like crazy. I now I'm gonna go with a 2inch lift and run 35"s I should get about 5in overall won't I?
Why not use you body on his frame? Moving body mounts (if needed?) & cut the box down to a short box and you would have a cool truck.
Kevin316 that is a really awsome idea!i think that is what im gonna do, if I do decide to go with that ill post a bunch of picks of the conversion for you guys.
