1977 Mid year changes
Old Oct 12, 2014 | 12:06 PM
beartracks's Avatar
beartracks
In mid 77 ford changed the frame and a few other things on the F-100. I'm trying to remember where the break is in the serial numbers. In particular I need to find out if I have the 33 1/2" or 37 1/2" wide frame and how to measure. I'm looking to fit a repop rear stock bumper from Bronco or Carpenter.
thanx
Old Oct 12, 2014 | 12:51 PM
mikeo0o0o0's Avatar
mikeo0o0o0
The narrow frame wasn't used on the F100. The narrow 34½" wide frame was used on the F250 4WD and the F350 cab and chassis.
Old Oct 12, 2014 | 02:07 PM
joshh's Avatar
joshh
all 73+ f100-f150 that i know of had the wide frame
Old Oct 12, 2014 | 02:14 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
The frame changed in 1973, not 1977.
33 1/2" width between the inner frame rails behind the cab: 1961/72 F100/350 ~ 1973/77 F250 4WD (High Boys) / 1973/79 F350 Cab 'n Chassis & Super Camper/Trailer Specials on the 140" wheelbase.
37 1/2" width between the inner frame rails behind the cab: 1973/79 F100 ~ 1973/79 F250 2WD ~ 1975/79 F150 ~ 1977/79 F250 4WD (Not High Boys) ~ 1973/79 F350's not listed above.
D3TZ-17906-A .. Chrome Contoured Rear Bumper-Use with 37 1/2" rear frame rails: 1973/79 F100/350 Stylesides & 1978/79 Bronco's.
The Bronco's bumper brackets are not the same as the trucks. Bronco's have a stone shield between the body and bumper, so its brackets are a different length.
77.5 aka mid-year (February) 1977 only refers to F250 4WD's.
1967/76 & 1977 F250 4WD's assembled before serial number Y20,001 are High Boys, have a divorced transfer case and an in-cab fuel tank.
1977 F250 4WD's assembled from serial number Y20,001 & 1978/79 F250 4WD's are not High Boys, have a married transfer case, no in-cab fuel tank.
Mike, if you look up 1973/79 rear bumpers (17906), you'll see these two frame rail measurements I listed.
Old Oct 12, 2014 | 02:15 PM
beartracks's Avatar
beartracks
Hmm, things get confusing with Alzhimers! At least I meet a lot of new friends! I'll do some more research and repost. I do know they changed some things in the middle of the 77 year. I'm pretty sure the starter tang was in a different location and I thought aftermarket headers offered two different part numbers. that's what led me to believer the frame had changed.
My frame is 37 1/2" from outside to outside edge measured at the back.
Thanks Bill.
Old Oct 12, 2014 | 02:46 PM
NumberDummy
The only changes that occurred mid year 1977 had to do with F250 4WD's assembled before/from serial number Y20,001.
There were no Super Cab High Boys, just Regular and Crew Cab Cab n' Chassis, Flareside & Styleside pickups, and with factory installed flat & stake beds.
69 cjshaker
Apr 6, 2018 07:40 PM
NorthwestX360
Jan 19, 2017 09:38 PM
Anthony487
Feb 10, 2016 01:33 PM
Feardeere7
24
Feb 15, 2013 06:57 PM
Chucky Babe
Jan 13, 2010 04:07 PM
