Dealer CAN"T Make a 2nd Key for Me!!!
So last week I bought my Excursion, and it only came with 1 key and remote. Today I went to the Ford Dealer to get a 2nd key made. They said it should only be about 20-25 minutes.......2 hours later the Service manager comes out and says they can't get my Excursion to take the new program. He said every time it completes like 90% of the program it just shuts down and won't do anything. He said they have never seen anything like this. He said they could start "diagnosing" the problem for $90/hour, but at this time they are unable to program me another key
Anyone have any ideas or suggestions?
-The Great
-The Great
Several good posts here . You can use standard keys , hide orig. , watch for battery draw . A good locksmith with proper certifications and tools can do it . It can take a while but problems with PATS should set codes dealer will see , try a different dealer . I just cut a second key for mine , non pats , in case of lock out . I also have a key pad on my door , if battery is dead pad won't work . Just my 2 cents .
Ya the dealer never said what the problem could be (or any codes for that matter), except that they could start "diagnosing" it for $90/hour
I also have a regular non-coded key just for the case of locked door.
-The Great
When the dealer makes copies , they have to program . All assigned Keys have to be present at program .If not , they will not work properly .They will unlock but not start .It can be used to cut a factory key , if factory key is lost . Key can also be cut by dealer if you show ownership and proper VIN . It still has to be programed . There are threads on this sight that show how to get past dealer program . I have not seen them work personally , but worth a look .
-The Great
I just want my keys to work properly. I am willing to pay the $120 for them to program new keys, but my local dealer says they can't because apparently my Excursion "won't take the program" even when they said they reflashed it. If a dealer can't make them work, i don't know what else to do. That's why I was turning to the Brethren for answers...
-The Great
-The Great
