heated mirror switch question
Old Feb 14, 2013 | 12:18 PM
Liquid10Rider's Avatar
Liquid10Rider
Hey guys I want to install a switch for heated mirrors and purchased an explorer mirror heat switch so it willl turn off by it self. the only thing is how do you wire it?? I just have the switch not the plug. Do you need the plug? or can you just use the switch and maybe solder on or use spade connectors?
Thank you,
-AJ
Old Feb 15, 2013 | 02:24 AM
BigAlsPSD's Avatar
BigAlsPSD
Having the pigtail would make a "cleaner" install, but either of your options could be done.
Old Feb 15, 2013 | 08:15 AM
tjc transport's Avatar
tjc transport
i ain't rite
i used a carling switch in my 02, and wired it to the ignition switch.
i leave it on when heated mirrors are needed, this way i know the mirrors will not ice up after the switch times out.
a very important feature to have when plowing.
Old Feb 15, 2013 | 10:43 AM
BillyBob69's Avatar
BillyBob69
Thank you,
-AJ
Search the web... I cant find it again but when I did my buddy's truck mirros, I know I ordered a pigtail for about $20 for the defrost switch from the 91 - 94 Explorer.
Or you can check your local salvage yards and get one from there.
I did the 94 exploder defrost switch on mine and it works great. Nice to have them shut off after 10 minutes.
Old Sep 13, 2013 | 09:06 AM
Liquid10Rider
hey guys I tried to find the plug end for the defroster switch that I picked up but I cant seem to find anything.... I even tried the dealer but no luck. please anyone with info let me know.
Thank you,
-AJ
Old Sep 13, 2013 | 03:52 PM
arcticatdan's Avatar
arcticatdan
Dig around at rockauto.com I have found connector there before.
Old Sep 14, 2013 | 06:21 AM
Supercab's Avatar
Supercab
I was wondering when I swap my mirrors to the '08-up style (with heat) IF I could use the window lock switch to operate the heat?
Old Sep 14, 2013 | 08:28 AM
Deluxe06's Avatar
Deluxe06
4000 rounds a min
Yes you could, just use it to control a relay to send power to the mirrors.
Old Sep 14, 2013 | 07:45 PM
Supercab's Avatar
Supercab
Wink
That's good to know! Thanks! Is there a separate switch in the '08 up trucks to handle the power fold and telescoping?? -wonder if somehow, without butchering my door panels I could swap in the later switches?
Old Sep 14, 2013 | 08:54 PM
Deluxe06's Avatar
Deluxe06
4000 rounds a min
don't know about that, maybe you could ask over at the 08 Forum
Old Sep 19, 2013 | 08:27 PM
Liquid10Rider
Hey guys i found out the part number from napa which is a food oem part number i have it at work so I'll post the number tomorrow. But the only problem is the switch i have is obsolete and the pigtail is hard to come by. One dealer on Ohio had one for 50 bucks so i picked it up. I did find a few online after the fact for around 25 . I will post the part number tomorrow thanks again for all the help
Also what size fuse should i use for the mirror heat? I read on another forum site how to do the wiring but they didn't state the fuse size?
AJ
Old Sep 20, 2013 | 07:40 AM
BillyBob69's Avatar
BillyBob69
The mirrors pull very little. I have a 10a inline for my mirrors.
As for the pigtail...if you haven't bought it yet, hold on. My buddy got his last spring and bought the pigtail new with the switch. I can get the info for you. It cost like $20. Works perfect too...I installed it all and it worked great.
Old Sep 20, 2013 | 08:35 AM
Liquid10Rider
Thank you for the offer but i had already picked it up.
Old Sep 23, 2013 | 11:14 AM
Liquid10Rider
here is the part number for the oem switch pigtail WPT377.
There are a few websites that still offer it but most are out of stock
-AJ
saddlethunder
Mar 3, 2019 08:52 PM
RailDawg
Jan 31, 2018 07:32 AM
rob17
6.7L Power Stroke Diesel
Feb 7, 2013 10:52 AM
93 mix 'n match
1997 - 2003 F150
Oct 10, 2011 12:07 AM
King0581
Apr 26, 2008 12:02 PM
