Ford frontend death wobble
Old Feb 14, 2013 | 12:20 AM
abriel68's Avatar
abriel68
After installing my 4" lift front leaf springs and the drop down pitman arm, I drove down the road hit a bump and instant death wobble, my front tires swerved left to right violently. I installed a steering damper, it improved but now when I steer to the right over 35mph or if I hit a bump/pot hole on the right tire it starts death wobbling, verrrry dangerous. Anyone have this problem before?
Old Feb 14, 2013 | 12:48 AM
Evan_P's Avatar
Evan_P
You need a track bar.
Old Feb 14, 2013 | 01:09 AM
abriel68's Avatar
abriel68
I removed sway bar from the front end(didn't reinstall), also I removed then lengthened the track bar and reinstalled it. Should I have kept the track bar the stock length? Also do I need the front sway bar? I have Farley new 35x22x12.50 at40psi. I'm going to jack it up and check my ball joints, and get an alignment on Friday.
Old Feb 14, 2013 | 08:26 AM
blkF250HD's Avatar
blkF250HD
Get an alignment and make sure they measure the caster. Not enough will cause a death wobble.
Old Feb 14, 2013 | 02:27 PM
abriel68's Avatar
abriel68
I rocked my tires from top to bottom and I have play on the right wheel and I can hear something moving so It feels like the top right ball joint, I'm going to replace my ball joints this weekend and get an alignment on Monday.
LiquidSteam
Jun 9, 2018 10:00 AM
9rudy9
Apr 28, 2016 03:24 AM
triton54
Offroad & 4x4
Oct 10, 2007 07:09 AM
resonance530
Aug 26, 2006 12:20 PM
hc130flyboy
May 24, 2005 08:24 PM
