WIF sensor corroded again?
Old Feb 14, 2013 | 09:05 PM
raptor131's Avatar
raptor131
Originally Posted by bismic
from what I can tell, that is water in the bottom, hard to tell how much, but there is water there. The algae grows preferentially in the areas of water pockets. Water will sink and form small pools like in your pics.
I agree with Bud - many fuel additives help prevent algae growth.
I'm thinking this is common with trucks such as mine, that sit more than they work, diesel sitting in a dark damp place for extended periods grows crap. This is how I know there is life on mars. If I can grow algae in a tank of diesel fuel. There is life on other planets. Lol
Old Feb 14, 2013 | 10:18 PM
Ian123's Avatar
Ian123
I agree, how does the algae even find its way in there? Its like the man-made lake in my neighborhood that somehow has fish in it (no, the HOA did not pay for someone to put them in there).
Anyways now the question is, are those few droplets of water enough to trigger the WIF sensor, or is it corroded and giving me a false warning?
Old Feb 21, 2013 | 06:47 PM
Ian123's Avatar
Ian123
Update: Today I drained the separator again, this time with under a half tank and it stopped draining after it filled up a water bottle. Once again, no water. I went ahead and sprayed a bunch of brake cleaner in there and a some more rust/bacteria came out but not as much as I was expecting.
I then drove to and from school with no water in fuel message...then I filled up my tank, went to the gym and on my way home it came on again! This is driving me crazy now and I don't know what else to do aside from replacing a HFCM that probably isn't bad in the first place.
Do you guys think its possible that for some reason, straight diesel fuel is getting sent into the separator and triggering the warning that its full of water? That's all I can think of right now.
Old Feb 21, 2013 | 06:57 PM
Misky6.0's Avatar
Misky6.0
I use diesel klean in every tank.
I used about 25% of a can of carb cleaner
with the straw tip. Got lots and lots of gold /brown goop off every side in the drain hole.
It's several months and no more wif lite.
I was getting it once in a while and only a few
drops of water in the clear jar.
Might be a corroded sensor?
Old Feb 21, 2013 | 07:11 PM
BPofMD's Avatar
BPofMD
Veteran: Navy
Actually, the sensor itself is probably bad now and must be replaced..... I don't know, but I THINK I remember that it can be. If you check in the READ FIRST section about the 6.0. that info is in there? Maybe use the SEARCH function.
Old Feb 21, 2013 | 07:19 PM
Ian123's Avatar
Ian123
The newest TSB says to replace the HFCM itself instead of just the sensor
Old Feb 21, 2013 | 10:47 PM
Yahiko's Avatar
Yahiko
Air moves in and out of the tank and spores just hitch a ride
in. They find a pool of water and feed on the diesel.
Sean
Old Feb 25, 2013 | 09:49 AM
mmenzies's Avatar
mmenzies
you might want to try and take the cover off and give it a good cleaning rather than just spraying through the drain hole. Probably need a new gasket on hand though.
Mark
Old Feb 25, 2013 | 11:22 AM
Ian123's Avatar
Ian123
I plan to take the cover off, clean everything and replace the sensor one of these days. For now I just have to deal with the water in fuel message every time I drive the truck
Old Feb 26, 2013 | 11:32 AM
raptor131's Avatar
raptor131
When I suggest to utilize the brake cleaner, you must remove the large fuel filter first, not just opening the drain plug and spraying it in there , you don't want the main fuel filter getting soaked with brake cleaner and possibly getting into the injectors. This way the HFCM is open in the front and then the drain plug is open.
Old Feb 26, 2013 | 12:10 PM
Ian123's Avatar
Ian123
So did I screw up?
I only sprayed it towards the front of the truck not towards the filter and I let it all drain out for 20-25 mins.
EDIT: also from this picture I found of an open HFCM, it doesn't appear that spraying it in the drain plug hole would allow it to get to the fuel filter
Old Feb 26, 2013 | 01:48 PM
raptor131's Avatar
raptor131
So did I screw up?
Your probably fine, I just wanted to clarify that point, for in the future. The whole problem with a sensor detecting water when you suspect there is none to me is either , there is water or debris in there, or the sensor is in fact defective. Like I was saying the last time this same thing happened to me it was algae and debris brought on by neglect of service of the lower fuel filter. The truck I helped work on had a wif light that would also not go out, disassembled the HFCM and went to town with 2 cans of brake cleaner and compressed air, the amount of crap that came out was unreal and looked nasty, it had looked like the previous person to work on the truck didn't know it had a fuel filter down there. After we cleaned it thoroughly the light went out and has not come back on since
Old Mar 2, 2013 | 10:13 AM
  #28
04KingRanch's Avatar
04KingRanch
I too am having the same problem as Ian123 right now. Ian, does your truck go back to an idle every time the light come on? Mine does and it even shut off one time last night. I am going to try and get a new sensor and clean out the HFCM as much as possible this weekend. I am new to the diesel world and I am finding out that possibly the previous owner of my truck was too.
Adam
Old Mar 2, 2013 | 11:26 AM
  #29
Ian123's Avatar
Ian123
Adam
Nothing happens to the truck when my light comes on. You might have another issue causing it to shut off like that.
srkr
6.7L Power Stroke Diesel
Aug 30, 2011 07:14 PM
scotiadallas
May 29, 2011 05:54 PM
pdarbs
Oct 28, 2010 03:05 PM
Jayybird
Oct 5, 2010 01:12 PM
chi6488
6.4L Power Stroke Diesel
Sep 27, 2009 01:24 PM
