ScanGuage 2 x guages
Old Feb 13, 2013 | 04:30 PM
jiveturkey692000's Avatar
jiveturkey692000
Finally hooked my scanguage up. Can someone tell me what xguages I should be looking for? Or what they are. Thanks for any info.
Old Feb 13, 2013 | 04:49 PM
npccpartsman's Avatar
npccpartsman
Xgauges have to be programmed in but it's pretty simple. I'm at my work computer so I don't have the list but Benny or Amdriven2liv can get them for you. I'm not sure if they're in the tech folder or not.
Old Feb 13, 2013 | 04:55 PM
Monster-4's Avatar
Monster-4
Here is a PDF I made awhile ago of all the gauge codes. It's might be missing a few but should cover the most common ones.
2003-2007 Ford Super Duty 6.0L PSD ScanGauge II XGauge Codes V6.pdf
Old Feb 13, 2013 | 08:23 PM
amdriven2liv's Avatar
amdriven2liv
I'm hitting easy street
A video to help:
Old Feb 13, 2013 | 08:25 PM
CPB1's Avatar
CPB1
KO=KEY ON LI=LOW IDLE HI=HIGH IDLE OR=OPERATING RANGE
FICM Vehicle Power (Volts) (Should be 12 Volts, should not drop below 10.25 for more than 60 seconds, or 9.0 for 4 seconds. TSB 09-24-03)
TXD: 07E02209CE
RXF: 0462450906CE
RXD: 3010
MTH: 006401000000
NAM: FVP
KO=12.0 LI=14.0 HI=14.0 OR=10.5-15.5
FICM Logic Power (Volts) (Should be 12 volts)
TXD: 07E02209CF
RXF: 0462450906CF
RXD: 3010
MTH: 006401000000
NAM: FLP
KO=12.0 LI=13.5 HI=13.5 OR=10.5-15.5
FICM Main Power (Volts) (Should be 47-48) Your FMP should never dip below 45. If it does, your FICM is toast and needs repaired or replaced.
TXD: 07E02209D0
RXF: 0462450906D0
RXD: 3010
MTH: 006401000000
NAM: FMP
KO=47 LI=47.5 HI=47.5 OR=40-52 (yes, that is what it says from Ford)
VGT Duty Cycle (%)
TXD: 07E022096D
RXF: 04620509066D
RXD: 3010
MTH: 00647FFF0000
NAM: VGT
KO=0 LI=73 HI=43 OR=0-100 %
Engine Oil Temp
TXD: 07E0221310
RXF: 046245130610
RXD: 3010
MTH: 00090005F05F (00090005FFD8 alternate MTH found)
NAM: EOT
Engine hot KO=190 LI=190 HI=190 OR= -40 - 302 *F
Trans. Fluid Temp
TXD: 07E1221674
RXF: 046205160674
RXD: 3010
MTH: 000100080000
NAM: TFT
Inj. Control Press. (ICP / HPOP)
TXD: 07E0221446
RXF: 046205140646
RXD: 3010
MTH: 003900640000 003900640000
NAM: ICP
KO=0 LI=625.5 HI=1400-1450 OR=0-4045
ICP Voltage (Volts)
TXD: 07E02216AD
RXF: 0462451606AD
RXD: 3010
MTH: 004827100000
NAM: ICV
KO=0.2 LI=1.0 HI=1.8 OR=.15-4.7 Volts
IPR Duty Cycle
TXD: 07E0221434
RXF: 046285140634
RXD: 3008
MTH: 0DCA03E8000A
NAM: IPR %
KO=14.84 LI=24 HI=40.60 OR=0-50 %
Throttle Position 1 (Volts)
TXD: 07E0220917
RXF: 046245090617
RXD: 3010
MTH: 006404000000
NAM: TP1
Note: Voltage of the ETC Throttle Position Sensor number 1
KO=4.0 LI=4.0 HI=3.4 OR=0.7 - 4.2 VOLT Accelerator Pedal Track 1
EGR Duty Cycle (Percent)
TXD: 07E022166E
RXF: 04620516066E
RXD: 3010
MTH: 006440000000 006440000000
NAM: EGR
KO=0 LI=0-15 HI=32 OR=0-44 %
EGR Throttle Position Control Signal
TXD: 07E022096C
RXF: 04620509066C
RXD: 3010
MTH: 00647FFF0000
NAM: ETP
EGR Valve Position (mm)
TXD: 07E022096A
RXF: 04620509066A
RXD: 3010
MTH: 000100010000
NAM: EVP
Note: EGR Valve Position in hundredths of a millimeter, where 0 mm indicates a closed EGR valve position.
EGR Valve Position Desired (%)
TXD: 07E02209D2
RXF: 0462050906D2
RXD: 3010
MTH: 00647FFF0000
NAM: EVD
EGR Valve Position Measured (%)
TXD: 07E02209FE
RXF: 0462050906FE
RXD: 3010
MTH: 00647FFF0000
NAM: EVM
Note: MEASURED EGR Valve Position, in %, where a low value indicates a closed EGR valve (0 EGR flow), and a high value indicates an open EGR valve.
KO=0 LI=0 HI=9.72 OR=0 - 14 PERCENT
EGR Valve Position (Volts 0-5)
TXD: 07E022167E
RXF: 04620516067E
RXD: 3010
MTH: 000133330000
NAM: EGV
KO=0.8 LI=0.8 -1.0 HI=1.3 OR=0.6 - 3.5 VOLT
Camshaft & Crankshaft Sync (1 = in sync, 0 = not in sync)
TXD: 07E02209CD
RXF: 0462050906CD
RXD: 3000 (3001 alternate)
MTH: 000100010000
NAM: SYC
KO=0 LI=1 HI=1 OR 0-1 (NO/YES)
Intake Air Temperature 2 (Fahrenheit)
TXD: 07E02216A8
RXF: 0462051606A8
RXD: 3010
MTH: 000100010000
NAM: IA2
Engine HOT KO=113 LI=113 HI=113 OR= -40-250 *F
Barometric Pressure
TXD: 07E0221127
RXF: 046285110627
RXD: 3008
MTH: 003100500000
NAM: BMP
Here is another BAR if the above one is not working for you. The one below works for me.
Barometric Pressure (PSI)
TXD: 07E0221442
RXF: 046285140642
RXD: 3010
MTH: 001D00500000
NAM: BAR
KO=96.5 (14) LI=96.5 (14) HI=96.5 (14) OR=50 - 120 (7.3 - 17.4) kPa (PSI)
Exhaust Back Pressure
TXD: 07E0221445
RXF: 046285140645
RXD: 3010
MTH: 001D00500000
NAM: EBP
KO=103 (15) LI=110 (16) HI=110 (16) OR=55 - 607 (8 -88) kPA (PSI)
Fuel Level
TXD: 007E02216C1
RXF: 0462451606C1
RXD: 3010
MTH: 000101480000
NAM: FL
Volume Fuel Desired
TXD: 07E0221411
RXF: 046245140611
RXD: 3010
MTH: 006400100000
NAM: VFD
Mass Fuel Desired (Milligrams Per Stroke)
TXD: 07E0221412
RXF: 046205140612
RXD: 3010
MTH: 000100100000
NAM: MFD
KO=0 LI=7.5 HI=10.7 OR=0-100
Engine Run Time (Minutes)
TXD: 07DF011F
RXF: 0441051F
RXD: 2810
MTH: 0001003C0000
NAM: ERT
Fan Speed Sensor (RPM)
TXD: 07E022099F
RXF: 04620509069F
RXD: 3010
MTH: 000100040000
NAM: FSS
KO=0 LI=533 HI=488 OR=0-4000
Fan Speed Sensor Duty Cycle (%)
TXD: 07E022091F
RXF: 04624509061F
RXD: 3010
MTH: 013103E80000
NAM: FDC
Manifold Absolute Pressure (PSI) (BOOST)
TXD: 07E0221440
RXF: 046285140640
RXD: 3010
MTH: 012203200000
NAM: PSI
Fuel Injector Pulse Width (Microseconds)
TXD: 07E0221410
RXF: 046205140610
RXD: 3010
MTH: 000800010000
NAM: FPW
COUNTS MISFIRES IN EACH CYLINDER
Cylinder #1 Cumulative Misfires
TXD: 07E022160E
RXF: 04620516060E
RXD: 3010
MTH: 000100010000
NAM: 1CM
Cylinder #2 Cumulative Misfires
TXD: 07E022160F
RXF: 04620516060F
RXD: 3010
MTH: 000100010000
NAM: 2CM
Cylinder #3 Cumulative Misfires
TXD: 07E0221610
RXF: 046205160610
RXD: 3010
MTH: 000100010000
NAM: 3CM
Cylinder #4 Cumulative Misfires
TXD: 07E0221611
RXF: 046205160611
RXD: 3010
MTH: 000100010000
NAM: 4CM
Cylinder #5 Cumulative Misfires
TXD: 07E0221612
RXF: 046205160612
RXD: 3010
MTH: 000100010000
NAM: 5CM
Cylinder #6 Cumulative Misfires
TXD: 07E0221613
RXF: 046205160613
RXD: 3010
MTH: 000100010000
NAM: 6CM
Cylinder #7 Cumulative Misfires
TXD: 07E0221614
RXF: 046205160614
RXD: 3010
MTH: 000100010000
NAM: 7CM
Cylinder #8 Cumulative Misfires
TXD: 07E0221615
RXF: 046205160615
RXD: 3010
MTH: 000100010000
NAM: 8CM
Gear (Transmission Gear)
TXD: 07E12211B3
RXF: 0462051106B3
RXD: 3008
MTH: 000100020000
NAM: GER
Self explained
Vehicle Speed Sensor (MPH)
TXD: 07E02211C1
RXF: 0462051106C1
RXD: 3010
MTH: 000102000000
NAM: VSS
Self explained
Accelerator Pedal Position (%)
TXD: 07E02209D4
RXF: 0462050906D4
RXD: 3008
MTH: 000100020000
NAM: AP%
Key On=0 LI=0 HI=13 Op range=0-17.75 (mine reads up to 99%, not sure why)
Old Feb 13, 2013 | 08:50 PM
jiveturkey692000
Wow that's alot of codes lol. Thanks guys. I'll read into that a little more when I get home from work. And definatley watch the video!
Old Feb 15, 2013 | 09:39 PM
jiveturkey692000
Finally got to load a couple. My Ficm is at 48V and my EOT is 179 and FWT is 175. Seems pretty good to me.
Old Feb 16, 2013 | 06:17 AM
MC5C's Avatar
MC5C
coolant temp of 175 is definitely low, indicating a bad thermostat. Amazing how common that is, I did one in the fall. Oil temp is also low, but in this case that's good and bad - good that the oil cooler is keeping the temp close to the coolant temp but bad that the oil isn't getting up to the desired temp of around 195 to 200 degrees.
Brian
Old Feb 16, 2013 | 07:39 AM
jiveturkey692000
That will cause low fuel mileage right? Because mine seems to suck.
Old Feb 16, 2013 | 07:51 AM
MC5C's Avatar
MC5C
It will probably cause a slow warm up from a cold start, which is what actually causes most poor fuel mileage problems. When you do a cold start the turbo vanes are commanded closed, reducing power and performance but creating back-pressure that helps to warm up the engine faster, and the transmission uses an alternate fourth gear that is actually overdrive third (it's actually a six speed auto) to make the engine rev higher, again to warm up faster. The injection pulse width is far higher when cold, putting a lot more fuel into the engine.
I did some fuel mileage runs after a cold start, and then comparing to when the engine is warm. If I do a cold start (32F), let the engine idle until the glow plugs go off, then drive 15 miles in mixed suburban driving (some 25 mph stretches, some 50 mph stretches) I get around 7 - 8 mpg for that run. If I do the same run with the engine fully up to temp I get around 15 mpg. When I do a long highway run, unloaded, I get around 21 - 22 mpg. Having established that, I now monitor mileage but no longer worry about it. It is what it is.
Edit: apologies for turning this towards fuel mileage, but here is another observation. Even on a highway run the extra fuel used from simply stopping to refuel and getting back on the highway makes a big difference. I recently did a 700 km run on one tank. The fuel usage monitor (Scangauge II) started the run at around 10 mpg, after the first hour was around 15 mpg, after four hours had stabilized at around 21 mpg. Stopped for a pee break, next hour was around 15 mpg then down to 21 mpg by hour three. This was average for the driving session, which is one of the modes the Scangauge allows. Overall mpg for the day was about 21.5. The next day I had a decent headwind, and the best I saw was about 18 - 19.
Brian
Old Feb 16, 2013 | 08:13 AM
jiveturkey692000
Well my truck does alot of idling when its cold so I know that's a lot of the problem. My truck runs horrible when its cold. If I dont let it run for ten minutes when its cold it seems to surge if I try to baby it at low speeds, 5-25mph. When it runs for 10-15 min in the driveway its fine. I don't know if fhats normal or not. My 7.3 if I was running late I could just go. I'm averaging about 11-12 mpg on a tank. I am going to order some filters and switch to synthetic oil. I don't know what the previous owner has in it or has done to it.
Also my turbo seems to be working fine even when cold. I can hear it and the gauge shows it. Or is there more to it then that.
Old Feb 16, 2013 | 09:00 AM
MC5C's Avatar
MC5C
Going to a ford dealer and getting the latest flashes will really improve the cold running. Mine rattles for 2 - 3 seconds then a smooth idle, and if I want to I can drive it away at that point. I like to let it idle till the glow plugs turn off, but I don't have to.
Brian
Old Feb 16, 2013 | 09:27 AM
jiveturkey692000
How long do the glow plugs stay on? I cycle the key three times using the light to go by. Then it starts pretty smooth. It idles fine when cold. Just when I go to take off when its cold it seems to surge or lose power a little and I have to give it more pedal. When I start my truck this morning cold I will be able to see what FICM is doing on a cold start.
Old Feb 16, 2013 | 09:35 AM
Restlesswildman's Avatar
Restlesswildman
I was told the glow plugs are on for 2 minutes after start up.
Old Feb 16, 2013 | 09:55 AM
amdriven2liv
About 2 minutes they will be on, that includes time the light is on. Cycling the key wont do much unless you do it after the first 2 minutes.
They will turn off sooner, depending on temperature. You can watch your volt gauge and tell when they turn off. there is a PID that times the glow plugs, but haven't gotten the xgauge to work right on them. So, I just use my volt gauge.
Volts will be in the 11v area, then when they turn off the volts will rise up to where they should be. 13.8-14v
