302 carb help
Old Feb 12, 2013 | 11:26 PM
sharpie_94's Avatar
sharpie_94
302 carb help
hi guys need some help picking a carb for my 302 in my 69 f100 ive read different things but seems to me about a 550 cfm would be best? right now i have a holley 750 double pumper bolted to a edelbrock torker manifold and 3 inch exhaust. gonna stick with the manifold and i want to keep the 3 inch exhaust cus it sounds sooooo good. but other than that the motor is stock. and its a 3 spd manual if that makes a difference. im a mechanic and know a bit about carbs mainly from working on my bikes and i like to fiddle. any info would be appreciated
thanks
James
Old Feb 12, 2013 | 11:42 PM
67-F100's Avatar
67-F100
A 750 is way too big. You need a 600 or 650 vac secondaries.
Old Feb 14, 2013 | 12:39 AM
sharpie_94's Avatar
sharpie_94
thanks man
Old Feb 14, 2013 | 12:42 AM
sharpie_94's Avatar
sharpie_94
bah just realized i got the manifolds mixed up. would i notice much of a difference going to a performer rather than a torker? (just picked up a 600 gona go through it and install it tomoz)
Old Feb 14, 2013 | 12:57 AM
67-F100's Avatar
67-F100
I never liked the torqer intakes. I've had good luck with performer and performer rpm intakes. Dual plane is best for a stock/street built motor.
Old Feb 14, 2013 | 08:07 AM
Freightrain's Avatar
Freightrain
You'll notice more response out of just putting a 600 Vacuum over that 750 DP. That is WAYYY too much carb for a stock 302.
Likely the Performer will be best for a stock motor.
Old Feb 14, 2013 | 11:02 AM
MIKES 68 F100's Avatar
MIKES 68 F100
TORKER IS A HIGH RPM MANIFOLD , you might want to switch that out too as it's robbing your engine of torque
Old Feb 14, 2013 | 02:03 PM
willowbilly3's Avatar
willowbilly3
Performer intake is pretty much comparable to a stock 4 bbl. Even if you can find one from an 80s mustang (aluminum version) they perform pretty good.
Yeah, you definitely want a dual plane for a street driver.
tractormanbill
May 18, 2013 05:17 PM
gtuttle
Nov 9, 2008 07:17 PM
WALFORD'S 56
30
Apr 11, 2008 06:26 PM
araiderfan2001
Apr 19, 2003 11:49 PM
