Injector reliability.
Old Feb 12, 2013 | 07:24 PM
sledhead999's Avatar
sledhead999
The .pdf shows they are EDM. Maybe they vary...
Ford Truck Enthusiasts Forums - View Single Post - Injectors: let's take a vote!
Old Feb 12, 2013 | 07:37 PM
rtalich's Avatar
rtalich
Great discussion!! If someone chooses to go with something bigger than 160/100's only to have them detuned for what they currently have... in my case I have a 38R, 4" exhaust, DP Tuner and HD4R100. What would I need in addition to that in order to run bigger injectors to their full potential? What would be the injector size limit if I didn't do any further mods other than a T500?
Old Feb 12, 2013 | 08:51 PM
jkidd_39's Avatar
jkidd_39
You will just push your 38r further with larger injectors.
I would recommend head studs and pushrods/valve springs once you start going after HP. Also, i would check out your fuel pressure under full tilt.. might wanna upgrade to an Frx or RR fuel system
Old Feb 14, 2013 | 05:40 AM
Texas Chain Ring's Avatar
Texas Chain Ring
I don't like the idea of 80's being turned into 100's and causing issues. Although I still have many questions and much to learn, 238/200's or 160/80's is what I believe it's boiling down to from this thread's info.
Btw, the injectors will be brand new. Thanks for that help, Tugly.
Old Feb 14, 2013 | 06:25 AM
Tugly's Avatar
Tugly
I just had time to pop in on this right on cue. In deference to my esteemed colleague, 2000ca250, I need to add a caveat to what he says. Stock is a split-shot. AC is a single shot. If you take these two injectors and give them precisely the same PW, the AC will give more fuel and do it earlier (higher HP, lower EGTs).
  • ACs "off the shelf" can be replaced from the shelf at an IH dealer if you ever need one injector... but the difference in wear will leave the engine unbalanced. I know what a fan you are of stock configurations, so this is the one to feed that urge. The AC stick is engineered for the HO T444E, the fraternal twin of the Powerstroke 7.3L. Somebody has already done their homework and it is a truely "safe" power bump... but you still have to change the tuning.
  • AC 160/100 is the sweet spot for reaching for the permagrin while hangin' on for dear life to the DD reliability. That's why I chose them. By going new, this will help many miles down the road because custom nozzles put you in the "all or none" practice at replacement time. Replacing one or two sticks here and there just introduces imbalance in the engine... thereby increasing wear. And yes, they can be dialed way back to stock (or less)... but the idle will not be quite as quiet as stock. Not too loud, just different-sounding (like an OBS truck)
I have a 2000 and I don't need to worry about PMRs... but all documentation on the matter says the PMRs are good up to 450HP. I say there's nothing wrong with AC 160/100 and a 375 HP tune. This will keep all needles in the green, the air is nice and clean, but ricers will learn you're mean.
Old Feb 14, 2013 | 09:20 AM
Texas Chain Ring
Thanks Tugly but I don't want ricers to think I'm mean nor do I want to waist my time embarrassing school children. I want to blow the big 6.7 that shamed me at a light the other day (while I was in 140), be able to do it with the bed fully loaded, back to the good ole days of the 7.3. And I still want to be able to do it with the same injectors 100k miles down the road.
I like the fact that the bigger nozzles can lower egt's, that's a technical tidbit of information I was as well unaware of, but the question now is what's the first number stand for in these injector numbers, the 160 or the 238 or 250..?? I know the second number is in direct relation of how much fuel the nozzle can flow compared to the stock nozzle, not certain the first number.
Please spare the noob. Thanks.
Old Feb 14, 2013 | 09:25 AM
jkidd_39's Avatar
jkidd_39
First number is how much fuel the injector flows per 1000 injections iirc..
so 160cc, 238cc, 250cc, ect..
The second number is percentage over stock.. 30/60/100 ect ect.
Just be happy you got a ford.. cummins boys are all screwed up.. HP rating.. LPM, LPH, percentage over, gpm.. it's terrible
Old Feb 14, 2013 | 09:40 AM
Texas Chain Ring
Can I ask what the the numbers are for a stock injector?
Old Feb 14, 2013 | 09:46 AM
jkidd_39's Avatar
jkidd_39
On a super duty iirc it's 130cc. I think 115 or 120cc for an OBS
Old Feb 14, 2013 | 10:23 AM
indyF-350psd's Avatar
indyF-350psd
you can't fix stupid!
youre going to need alot more than injectors if you want to accomplish this! basically its not going to happen with a fully loaded bed.....doesnt matter what sticks you put in the stock turbo is going to limit you....if youre running a stock hpop that will limit you....fuel system....heads.....the list goes on and on....if you want a reliable work truck put in some ac's or swamps 175/146 sticks and be happy....if you want fire breathing horsepower youre looking at alot more.....unlike all the others who werent or arent happy with "stage 1's" i am more than happy with mine....paired with my h2e it tows very well.....you need to decide how much horsepower you want and then decide how much disposable income you have.....if you go the cheap route....it wont be reliable....jmo...
Old Feb 14, 2013 | 11:05 AM
Texas Chain Ring
That 6.7 took three lengths to my every one off the light, both of us empty. Pitiful how slow my truck was, how slow she is. That was the day it hit me that I need to come of age.
The bed fully loaded was an exaggeration of my day dreaming. I know what all is involved with keeping up with Jone's, it'll happen just piece by piece.
I'm really leaning towards the 238/200's so that if and when I do purchase a 2000 model 7.3 than I can swap injectors and get the most potential power from them on that truck. I just hope they work properly in this one.
Old Feb 14, 2013 | 11:11 AM
Stewart_H's Avatar
Stewart_H
AC's can be had new, but not hybrids.
Stewart
Old Feb 14, 2013 | 11:13 AM
  #28
Texas Chain Ring
Oh man this just keeps getting better. Please explain.
Old Feb 14, 2013 | 11:21 AM
  #29
Texas Chain Ring
All I know is I want and must have brand new injectors, I can't take the risk at the moment of used giving me troubles. If what you say is true Stewart then what would you recommend now, knowing I must have new? What's the biggest I can get, the most "powerful" so to speak...?
Old Feb 14, 2013 | 11:30 AM
  #30
fordpride's Avatar
fordpride
AA 90cc OBS
AB 120cc OBS Cali model and e99
AD 140cc 99-03
AC 160cc
