Aluminum Radiator
1959-1965 Ford Pickup Truck New All Aluminum Radiator 1959 1960 1961 1962 1963 1964 1965
Seems like most people have gone with the Jegs aftermarket radiator, but this one seems like it would be a better fit.
Any input would be appreciated, thank you!
John
Apparently they don't actually make them for the 292 so they would have charged me and modified it before the shipped it. But still no complaints. A quick couple of phone calls and I found a place to do it and test it.
Now is a good time to switch to an electric fan if you haven't already... run cooler, and free up horsepower
Cap-A-Radiator
Thermal Conductivity of some common Materials and Gases
I say compare the costs for starters. This is always the controlling factor for me.
Copper and brass have higher heat conductivity than aluminum, but older rads have a tendency to corrode/foul/plug easier. Newer copper/brass radiators do not have this problem due to a change in manufacturing methods. Copper/brass radiators are also easier to repair. They are also heavier.
Aluminum has lower thermal conductivity than copper/brass. It is lighter. It looks really nice. It is harder to repair.
You also start to get into the entire mixed metal debate and galvanic corrosion. In an engine you have multiple types of metal, steel, cast iron, copper, brass, and aluminum generally. Due to a bunch of scientific crap and how these metals react with each other mixing everything together is generally a bad idea, even with 50/50 antifreeze water. Wikipedia has a decent explanation on how it works.
Galvanic corrosion - Wikipedia, the free encyclopedia
Galvanic Corrosion, theory documents Galvanic Bimetallic Corrosion
In short, buy what you want. Dont discount a quality made copper/brass radiator over an aluminum one. A properly manufactured copper/brass radiator will cool better than an aluminum one. Aluminum does have its advantages as well.
We have a 1964 F100 that we are dropping a 351w in and need to know what options we have for replacing the original radiator. We are new to all of this and want to make sure that we don't waste money on the wrong radiator set up. My son is paying for everything and he is only 16! Is it as easy as buying an original-fit radiator or are there special considerations with the engine swap to the 351w?
Thanks,
Joe and Josh
1964 F100 Custom Cab, 292 Y-block
2011 Mustang GT, Kona Blue, 6-spd manual
Radiators - Seattle Radiator Works - radiator repair in Seattle
Chad
If those locations and sizes are ok with the stock radiator, then you may not even need to replace it. The stock radiator will cool a stock to mild Windsor just fine.
If the radiator needs repair or replacement, then you can get Chinese direct fit aluminum radiators for a very reasonable price. Some of the suppliers can even modify the inlet / outlet locations for an additional fee, to work perfectly with whichever engine you choose.
If you prefer American made, there are options for that, too, but expect to pay about 2 to 3 times the price.
John
https://www.ford-trucks.com/forums/1...radiators.html
Advanced auto sells a carquest #433433,it's a 2 core aluminum for $139.
Cheaper with a coupon.
It almost fits,almost.
The bolt holes line up, this is good.
It's a front attached ,we need one that attaches from the rear, good news,the sides are bolted on, flip them over. But it still won't fit, so you space it out toward the motor 3/4"
For spacers I used 1/2" nuts, taped two together and it worked out.
The bolts are 3/8-16 so pick up 4 new ones 2" long
The bottom outlet is 1 3/4" so we need a hose. Dayco C70737, it's 2" on one end 1 3/4 on the other.there is no spring in it so take it out of your old hose and twist it in the new one, put your clams on.
Top hose, the outlet is both 2" and 13/4" ,if your old hose is good put it on,your done. If not get a gates hose #21034, the hose is " and 13/4 on the other end. But it won't fit,so cut 13/4" off the 2" end, but now it won't slip on,it will just start,so use your heat gun to stretch it a little, I had an extra spring so I twisted it in there to, but it's the pressure side,so it should not collapse, but the bottom suction could without the spring inside.
Your done and you get a life time guarantee.
I have pictures but can't load them
Hope this helps someone else
I haven't pulled mine yet, but from looking at it they appear solid mounted from the factory.
