LEDs
Old Feb 10, 2013 | 07:43 PM
austinlibke's Avatar
austinlibke
LEDs
So, stupid question. I want to swap some LED bulbs in for my cab lights. and parking lights. but I have heard that i may have to wire in a resistor.. I know that LEDs use less juice so maybe the full voltage could burn them out? not sure. Any words of wisdom would be awesome! Thanks
Old Feb 10, 2013 | 08:18 PM
Daniel5.0's Avatar
Daniel5.0
Only place you'll need a resistor is for the turn signals. The high current is required to make a standard flasher operate properly. Install a flasher made for LEDs like this one, and you can forget about the resistors entirely.
Old Feb 10, 2013 | 08:36 PM
austinlibke
Alright. sounds awesome. Thanks!
Old Feb 11, 2013 | 09:26 AM
raystankewitz's Avatar
raystankewitz
LED's are not liked by our trucks that have a RABS module. You will most likely nead to put the load resistors in place, since the LED's do not pull enough of a load and the computer thinks the taillights are burned out.
Read this thread for more info.
https://www.ford-trucks.com/forums/1...-light-on.html
Ray
Old Feb 11, 2013 | 12:51 PM
Daniel5.0's Avatar
Daniel5.0
News to me, thank you.
Old Feb 11, 2013 | 01:31 PM
White 97 xlt's Avatar
White 97 xlt
Originally Posted by raystankewitz;12826142[B
]LED's are not liked by our trucks that have a RABS module. [/B]You will most likely nead to put the load resistors in place, since the LED's do not pull enough of a load and the computer thinks the taillights are burned out.
Ray
They give the E4OD transmissions fits too.. (shifting problems/converter lockup problems) It's an easy fix, load resistors are the cure!
Old Feb 11, 2013 | 07:44 PM
austinlibke
So do i still need the different flasher and the resistor, or just the resistor
Old Feb 11, 2013 | 08:35 PM
White 97 xlt
Just two resistors will fix you right up, one at each rear brake light. BTW the resistor goes from the wire going to the brake light filament to ground..
Old Feb 11, 2013 | 08:44 PM
TexasGuy001's Avatar
TexasGuy001
This is just my two cents. I wouldn't bother with LED's, for the reasons mentioned, and also because LEDs don't evenly reflect in the lights that were originally designed for incandescent.
DeeDubz
6.7L Power Stroke Diesel
13
May 17, 2016 12:05 PM
51PanelMan
26
Feb 16, 2013 10:14 PM
Jolly Roger Joe
47
Oct 18, 2012 06:21 PM
Jag Red 54
Mar 11, 2011 08:42 AM
jaye
13
Feb 16, 2009 04:03 PM
